BURN-BROS's Avatar
Who has the minerals to run this?
I know what it came off of, do you?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 01-08-2010, 10:43 AM
BURN-BROS's Avatar
3ldz comparison
Burnham Performance
Old 01-08-2010, 10:56 AM
I would rather be driving
jpnovak's Avatar
Toyota Racing MR2 LeMans
750 HP, 2140cc @2.5bar boost
I wonder if my 2.2L Targa could handle this? I should just "bolt right up".. Whaddya think Aaron?
Old 01-08-2010, 12:00 PM
Metal Guru
911nut's Avatar
That divided turbine inducer is useful only on a equal length exhaust (headers and collector, like a RarlyL8 header or a equal length inline 4).
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-08-2010, 01:01 PM
BURN-BROS's Avatar
the Toyota link is easy, what else ran it?
Well you are close on displacement...
Burnham Performance
Old 01-08-2010, 04:07 PM
BURN-BROS's Avatar
Yes,no, maybe. depends on what you mean by equal. Equal left and right exhaust, yes.
Here is a 935 header for a similar type turbo. Some doofus dorked up the wastegate circuit... Notice it's close to equal.
Burnham Performance
Old 01-08-2010, 04:14 PM
jpnovak's Avatar
935 Baby?
Old 01-09-2010, 12:42 PM
BURN-BROS's Avatar
around 1988, after the rules change... Interesting, at least for me.
3 liter DOHC V6
Eletramotive ended up in Carlsbad before Nissan pulled out of the program.
Burnham Performance
Old 01-09-2010, 01:15 PM
3 restos WIP = psycho
kenikh's Avatar
From the web...
From what I know about the racing history of the 3S-GT engines boost needs
> to be in the order of 1.5-1.7(24-28psi) bar boost to achieve this. Toyota
> originally used a CT44RT Turbo in their 1986 prototype racer at Le Mans
> this turbo boosted 2.5bar(37psi). The engine was rated at 550hp @ 1.4bar in
> 24Hr racing trim and 750hp @ 2.5bar in qualifying trim. These figures were
> achieved with a 2140cc(89x86) engine with a max 9000rpm and 8500rpm in race
> mode. These turbos had twin mechanical water cooled wastegates, I don't
> know that I want this sort of complication.
> In 1987 they switched to a CT44ST which offered 1.8(26.5psi) boost and used
> the RT unit for qualifying. They also increased the cylinder wall thickness
> by 2mm to cure a bore cracking problem( I think it was 2140cc motor, the
> 1998cc unit wasn't produced until 88/89) this engine was rated at
> 680hp/8500rpm and 470 ft/lb torque @ 5500rpm (as much as 900hp had been
> extracted on the test bench).
> The only other info I can find relates to the rally engine which produced
> 380-400hp on restricted turbo (more if you cheated like TTE).
> I believe that the CT44ST is used in GTP racing. Does anyone know where I
> can get one or more info about them? Either that or if you know of another
> unit that will flow the amount of air needed at the required boost.
> My mechanic suggested to me, that given the limited amount of cooling air,
> I might get better results by using series charge cooling i.e. water/air
> followed by air/air would give the best cooling with the least increase in
> intake volume. I have seen an article on an Aussie MR2 with a turbo charged
> 3S-GE and a neat water/air inter-cooler sitting above the cam cover and I
> have enough bits from the parts cars A/C system to make one. Has anybody
> had any experience with this type of charge cooling (it was used on 88/89
> Celicas)?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-09-2010, 01:18 PM
jpnovak's Avatar
I used to love watching Nissan dominate the IMSA GTP when I was a kid.
Old 01-09-2010, 02:08 PM
+1 and the Paul Newman days
Old 01-09-2010, 02:19 PM
BURN-BROS's Avatar
I met a guy up here in Camarillo that said here worked for Electramotive at the time. A couple of months later, he showed up with a photo album full of pics from development and the races....very cool. Next time I see him I'll see if I can scan some photos.
Back to the turbo, the turbine housing is an odd color, anybody familiar with the look of inconel? It's N.O.S. so it has not been discolored.
Burnham Performance
Old 01-09-2010, 04:55 PM
kenikh's Avatar
I've got some trash inconel parts in the garage. I'll take some pics.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-09-2010, 10:04 PM
BURN-BROS's Avatar
Thanks Dood, it's probably just a rust preventative applied to the housing. The wall thickness is pretty substaintial, so I would be suprised if it's anything more exotic than Ni-resist.
Burnham Performance
Old 01-10-2010, 09:58 AM
