-   -   "Matching" engine/tub numbers question (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/528434-matching-engine-tub-numbers-question.html)
e p slick 02-26-2010 01:14 PM
I have my 930 for sale
index
and have been asked if mine is the original engine that the car was built with.
I now ask you Pelicans: Where is the engine number and how do I know if it is or is not original.
EPS
pu911 02-26-2010 07:42 PM
EPS,
The engine serial number will be stamped into ridge that runs next to engine fan. You will need factory documentation (COA) to know if it is the original motor. You can get a decent idea if compare chassis number sequence with engine build sequence. PM me you VIN # and motor # and I can look it up for you.
Phil
