e p slick's Avatar
"Matching" engine/tub numbers question
I have my 930 for sale
index
and have been asked if mine is the original engine that the car was built with.
I now ask you Pelicans: Where is the engine number and how do I know if it is or is not original.
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 02-26-2010, 02:14 PM
EPS,
The engine serial number will be stamped into ridge that runs next to engine fan. You will need factory documentation (COA) to know if it is the original motor. You can get a decent idea if compare chassis number sequence with engine build sequence. PM me you VIN # and motor # and I can look it up for you.
Phil
Old 02-26-2010, 08:42 PM
