1988 930 Mixture Adjust
Just picked up an 88 930 and trying to get it to pass smog. Need to make a small adjustment to fuel mixture. Can I get some help finding the mixture adjustment and adjusting it just a tad richer. Much appreciated
Old 11-13-2019, 12:15 PM
Work in Progress
Rich76_911s's Avatar
Use a 3mm allen wrench in the circled adjustment screw.
You have to push the spring-loaded arm down and make small adjustments a 1/8 - 1/4 clockwise turn should richen the mixture a little.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 11-13-2019, 12:57 PM
Work in Progress
Hopefully, the image loads this time
Old 11-13-2019, 01:03 PM
mark houghton's Avatar
You have to push the spring loaded arm down and make small adjustments a 1/4 turn to the right should richen the mixture a little.
My experience is that 1/4 turn is like....wow....a whole bunch of love, unless the car is already so lean that it's hardly idling at all. A couple degrees make quite an impact on AFR's.
Push the spring loaded adjustment post down until it you feel contact, then holding it there you should feel resistance when trying to turn it CW or CCW, as it engages the adjustment thingy. Do this while the engine is running. Pushing down on the adjuster until contact....and then just a little bit more will cause a richer condition. If your rpm drops at that point, it was either right on or a bit too rich to start with. Conversely, if the rpm's increase then it was too lean to start with. Just rough "tune by ear" stuff but gets you in the ball park.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 11-13-2019, 01:11 PM
Can I access it without removing the airbox?
Old 11-13-2019, 02:55 PM
908/930's Avatar
Yes,
Does your car still have a O2 sensor?
Old 11-13-2019, 03:05 PM
I'll have to check. It's got exhaust with high flow cat, K27, cams etc on it. Just trying to get it past smog. Passes everything but NOX with lots of margin. Fiddled a little with the timing but that just made it worse, so next stop is making it a little richer.
Old 11-13-2019, 03:09 PM
FWIW in case you don't know, this only affects mixture at idle. Above about 1,500 it has little to no effect.
With the narrow band O2 sensor and a working CIS "brain" (and other components), you set the idle mix to the target spec with the "brain" disconnected, and then when connected the brain can use the O2 sensor and lambda valve to hold the idle mix at probably right around stoich.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 11-14-2019, 05:36 AM
Crotchety Old Bastard
RarlyL8's Avatar
If I were in your shoes I'd put the OEM cat/muffler back on for the test and $hit-can the high flow cat in place of a bypass pipe or straight through muffler. Any cat at all will hurt performance.
Old 11-14-2019, 05:56 AM
A/F ratio will affect HC and CO. NOX, not so much so. Check base timing and retard it a couple of degrees from stock spec. And yes, put the stock cat back on.
Old 11-14-2019, 06:32 AM
