934 Question
The 934 was the Group 4 version of the 930, so I think this is the best place. On the 934, and early 930's, there is a small cooler inside the whale tail, under the small grill. There are In and Out lines hooked to the left hinge.
What is this cooling? I am assuming, it's a transmission oil cooler. Where do the lines connect?
The reason I ask, is like a few others on the forum, I am doing an upgraded build of the Tamiya kit, which will include adding a few missing lines. This has been the mystery line.
Old 04-01-2025, 11:54 AM
dos531's Avatar
if its attached to the decklid, its the ac condenser.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 04-01-2025, 04:05 PM
David's Avatar
I believe it's a transmission cooler but I don't know for sure. You could use something like this:
https://www.fvd.net/de-en/915300911550/transmission-oil-cooler-915-930-transmissions.html
Old 04-03-2025, 09:24 AM
David's Avatar
The IROC cars have one too. You can kind of see it in the pic:
Old 04-03-2025, 09:26 AM
Ingenieur
Here is the Group 4 934 engine compartment. Are you referring to the air/water intercooler water tank?
Old 04-03-2025, 11:37 AM
David's Avatar
This has been a fun research project
Pic showing the extra engine vent at rear of tail:
Oil lines running up left side of tail hinge:
Oil line running to bottom of transmission:
Old 04-03-2025, 01:03 PM
Ingenieur
I see what you are referring to. I found this 1976 934, VIN 0060022. It does not seem to have a tail mounted cooler. Interesting.
Old 04-06-2025, 07:39 PM
