Protomotive Instructions??
Does anyone have instructions from Protomotive for a 3.2 conversion? Looking for a "check list" for my conversion.
thanks, Ben
1986 3.2 Carrera |
Ben,
Here is another link that might help you (thanks to charlesbahn for posting): Protomotive Stage ! Install (Part 1) Do a search and you will find a number of posts that will help you. I would recommend reading and learning as much as possible before buying anything (don't need to reinvent the wheel). Make a plan on what your goals and budget (don't forget to include AFR meter and boost gauge). And if you are going with stock compression, don't boost over .7 Bar! Good luck! Darrell
Darrell 1984 3.2 Carrera Turbo Cab - Protomotive chip, B&B Headers, M&K Exhaust, Garrett GT30, Tial WG (46mm), Custom Intercooler, "Big Reds" 993TT brakes, In-Your-Face Gauge Boost/AFR Gauge, and Removable Hardtop |
+1 I used the same instructions a few years ago, are you using a Protomotive FPR? They really make life easy instead of an adjustable but either way it's a pretty easy. Took me 2 afternoons and I took my time. What turbo are you using?
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
