-   -   New Dyno numbers...! (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/531725-new-dyno-numbers.html)
drmatera 03-19-2010 08:40 AM
i raised required fuel by 25% which richens the whole VE table by that amount. I am running 60# injectors that can support the power numbers i'm making... And I totally understand that e85 power peaks at a different "lambda" than gasoline. But since Lambda is lambda is lambda how can it get skewed the farther off stoich I go?
A = 1
Z = 26
if I say B or 2 it means the same thing regardless of the fact that the digit has a different shape. I'm not sure this can be explained anymore than it has been. lambda numbers are what they are PERIOD . The gauge could display the word boobies when at .8 and dog when at 1.0 That doesn't change the fact that it's still the lambda reading
RarlyL8 03-19-2010 10:52 AM
It should display dog at cruise and boobies at 1.0bar. I think that is the problem.
krasuskyp 03-19-2010 11:06 AM
Oh snap - WHERE do I score me on of *those*??? BRIAN GET ON IT!
http://forums.pelicanparts.com/uploa...1269021902.jpg
drmatera 03-19-2010 01:52 PM
bbrbrbrbrrrrrrrrrumsky
drmatera 03-19-2010 05:30 PM
while i could stare at those fun bags all night here is my dyno sheet
http://forums.pelicanparts.com/uploa...1269045023.jpg
Speedy Squirrel 03-19-2010 07:17 PM
Displacement = 3.3L or 0.0033 cubic meters
Lambda 1 = 9.8 A/F
RPM = 5500
Boost = 1.2 Bar or 221 KPA absolute manifold pressure
Inlet Man temp = 35 C (just a guess, but typical) or 273 + 35 = 308 K
Gas Constant = 0.287 KJ/Kg*K
Mass of air = [(221)(0.0033)]/[(0.287)*(308)] = 0.00825 Kg of air for every 2 revs
(0.00825/2)*5500 = 22.7 kg/min or 1361 kg/hr or 3000 lb/hr of air
3000/9.8 = 306 lb/hr of fuel
306/6 = 51 lb/hr of fuel per injector
You are running way over 20% rich so you need at least 20% more fuel: 1.2 * 51 = 61.2 lb/hr
But you have 60 lb/hr injectors, so you're done.
You can go back to staring at pictures of boobs now.
drmatera 03-20-2010 10:21 AM
yes, at 10.5 a/f (7.0 lambda) I saw 104% duty cycle on my injectors. I am aware that the 60's are done
BTW, my peak inlet temp was 115*F
Speedy Squirrel 03-21-2010 12:47 PM
Airflow = 3000 lb/hr
Boost = 1.2 bar (120 kPa)
3000/2.2 = 1364 Kg/hr
Volume flow = [(1364)(.287)(293)]/98.1 = 1169 m3/hr or 1169/3600 = 0.32 m3/sec
Pratio = (101 + 120)/101 = 2.19
Plot that on the map below. You are in no man's land. No wonder your intake temps were so warm, only 60% compressor efficiency. You should go up one turbine housing size also (no map for that unfortunately). You need bigger injectors and a bigger turbo. Things are adding up fast! I hope you do it though. E85 is a great answer for a turbo motor. Watch out for the Bosch fuel pumps (if that is what you are using). I think some of them use a white plastic around the motor armature the disolves when exposed to alcohol over time.
http://forums.pelicanparts.com/uploa...1269200611.jpg
fredmeister 03-22-2010 05:36 AM
what turbo was this compressor map from thats posted?
do you have one for the k27S turbo that you could send me or post it?
this is very valuable info.
thanks,
Fred
drmatera 03-22-2010 08:43 AM
wow, she is off the map. I ran it at the drag strip sunday. She went 12.75 @ 117.75mph at a race weight of 3190 (with me). The boost would slowly decrease as rpm climbed so I turned up the boost controller to try and compensate. At the top of the rpm range the boost always ended up around 16.5-17psi. My lambda was still around 7.0-7.3 all the way down the track (i added a few pounds of fuel pressure) and she ran like a champ.
speedy squirrel- thanks for all your technical input, i'm a simple guy, my knowledge of performance turbocharging is from the school of hard knocks... it's interesting to see the math behind it all.
Yes, i'm still on the stock fuel system. I'm watching carefully as the the bosch pumps don't like alcohol. I had a bosch 044 on my turbocharged mustang and it ran on E85 for 3 years. But when i broke the transmission the car sat for over a year. When it ran again the bosch was dead.
Speedy Squirrel 03-22-2010 06:38 PM
5327 988 7200
930.123.013.04
aka the "K27 7200"
[QUOTEdo you have one for the k27S turbo that you could send me or post it?
this is very valuable info.[/QUOTE]
No, I only know the Porsche part number at this time (930.123.003.03). I need the cross-reference number (5327 XXX XXXX) to come up with the correct compressor map. Do you have it? I suspect it is the same compressor though.
turbobrat930 03-22-2010 06:59 PM
Holy cow!!! 104%??? duty cycle... WOW
I was thinking of running 85 or 100lb injectors in mine when I run E-85. This is what I wanted to talk to you about over the phone. I think max we should be at 80% duty cycle. The bigger you go though, the idle will get harder to tune in.....
On a related note, I have a friend with a twin turbo big block producing over 2500 HP in a four door AMC Rambler.... he is using E-85... and loves the stuff!!
smurfbus 03-23-2010 12:06 AM
If you're going to swap for bigger injectors you should consider the Bosch EV14 injectors. Nice numbers on the strip.
drmatera 03-23-2010 09:08 AM
turbobrat - yeah we need to get in touch but i've been so busy with work I don't seem to have a moment to think during the week.
I've got a set of 80Lb injectors here i'm going to try. They can function at a lower duty cycle than the 60's so i may get an improvement in idle quality
drmatera 08-11-2011 05:37 PM
New update.....................
new dyno numbers with billet wheel S262
1.3 bar
450.3 rwhp / 436 rwtq
I'll post graph tomorrow
Ringmaster 08-11-2011 06:57 PM
1.3 bar
Nice numbers! Dynojet, Mustang or? What level of octane?
drmatera 08-11-2011 07:35 PM
It's a dynapac dyno and the car is running E85
TurboKraft 08-29-2011 10:32 PM
Well that works!
fletcher0780 08-30-2011 02:59 AM
you feel comfortable running 1.3bar (18.8 PSI) on your stock internal engine? I know your fuel and spark is modern, but I thought the issue with higher boost is hitting cyl pressure limits? I'm not sure where to top off my boost, currently I have ob fuel cut at 1 bar. Nice numbers by the way!
smurfbus 08-30-2011 03:49 AM
Time to hit the strip again or are they closed now?
