-   -   New Dyno numbers...! (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/531725-new-dyno-numbers.html)
911TT33 08-30-2011 02:49 AM
Time for a K27HF :cool:
wjfk32 08-30-2011 04:44 AM
Originally Posted by drmatera (Post 6191332)
New update.....................
new dyno numbers with billet wheel S262
1.3 bar
450.3 rwhp / 436 rwtq
I'll post graph tomorrow
Is that with just the change of the wheel in the k27???
Just figured it out... :) Congrats!
Is the turbo size comparative to a k27?
Walt
E-man930 08-30-2011 04:56 AM
"Time for a K27HF "
Nope... drmatera chose wisely... :cool:
JFairman 08-30-2011 06:35 AM
no way... that pos is the worst choice possible.
wjfk32 08-30-2011 06:47 AM
U guys are bad................... :) But true.
Walt
TurboKraft 08-30-2011 10:32 AM
Matera - your signature says B&B headers, custom muffler, Carrera manifold and custom full bay intercooler. Is this on a 3.3L with stock internals? Or did you port match the heads to the Carrera manifold or install cams?
fletcher0780 08-30-2011 11:22 AM
Chris, per his build thread:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/499101-efi-conversion-3.html#post4933588
Adapters look very similar to the ones I bought from you.
drmatera 08-30-2011 01:29 PM
Thanks guys. This is with my Bullseye Power S262. The old cast wheel made 384rwhp @ 15-16psi. With nothing more than a Billet "Batmowheel" (I didn't name it) and 17-18psi it made the 450rwhp. Needless to say I was stunned on the first pull when she made 420rwhp with 10 flat a/f ratio. I'm not too concerned with the power it's making as I keep the rpm to 6000 max. I've got most of my engine upgrade parts stashed away, all i'm needing now is some LN Engineering Nickies which I plan on calling TurboKraft for in the coming weeks.
Right now my engine is completely stock ( except for EFI). We made 1/2" thick aluminum reducers to mate the Carrera intake to the 3.3 head ports. My plans are to port match the heads, twin plug while i'm there and I have a pair of EVO cams waiting as well.
K27???? hahahaha, not on your life. If you want a limit yourself
fletcher0780 08-30-2011 02:01 PM
I'm going to keep letting you pave the way for me matera :)
Other than E85 and the better turbo, we are pretty similar right now. I would run E85, but it's nowhere to be found, so I'll have to settle for meth injection. I should get my car back on the rollers in the next month, after I get closed loop boost control working and get a water meth tank mounted in my engine bay. I know the K27 will limit me now, but I'd be happy (for now) if I could hit 375whp. I'll have to bump the boost and watch the IAT's. My meth nozzle will be down stream of my IAT sensor, so I should be able to see when the K27 hits the wall. Where did you get your borg turbo from? My next investment was going to be a garrett gtx3071, but I haven't read of one on a 930 yet and I've been doing well copying you so far :)
drmatera 08-30-2011 02:36 PM
I sell Bullseye Power turbos, thats why I am using one. For a stock 3.3 it's a bit large so I wouldn't recommend one for someone wanting to keep their motor stock and don't desire more than 400rwhp..
As for your K27 making 375rwhp, it's possible but not optimal.
