Looking for a set of Heads
In the middle of my rebuild and began second guessing the usability of my 'rebuilt' heads.
![]() ![]() Had mine rebuilt by my machinest who didn't there would be any problem running these (I have three with the damage in the first pic) and two with the damage in the bottom. Thats 5 out of 6 heads for those keeping score at home! The brain trust on the engine rebuilding forum all seem to agree that these shouldn't be run. Too bad I already paid to have them rebuilt (water under the bridge). Looking to see if what might be out there I could use as a replacement set. Would love to find a set that has been rebuilt but solid cores are fine. Also looking for a NEW suggestion for who I should have rebuild whatever I end up with. Thanks in advance.
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
sudo apt-get purge 930
edbaus has a set for sale.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
You really can't polish those out with a flapper wheel and have them decked to bring the CR back in line with what you are expecting??? Maybe it's just the picture, but it doesn't look that bad?
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
Here's a close up of the worst one...
Did they charge you to put those valve seats in? No one at the machine shop said anything to you?
Yes on the charge... nope on the other 'minor' issues. Didn't see them as having any real issue. The guy has a good reputation too.
If you have three good ones I may have the other three but mine were ported to match a Carrera intake with new valves let me know if I can help.
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
Thanks Lincoln but while the other three are far better than the first, I think there is still damage that would be prohibitively expensive to repair over sourcing new cores. I spoke with Ollies this AM and have a vmail into Supertec. Unfortunately this is looking to be an expensive fix.
I have a set of Turbo Kraft injector blocks, if you are running larger than stock intake on your heads.
Stuart
88' 930 03 Tacoma, 04 Duramax, 06 R350 Benz If you are traveling at the speed of light & turn on your headlights, does anything happen? |
Thank all. I think I've got myself squared away.
So what is the solution? Weld the heads or buy new cores? Inquiring minds want to know
