Problem with 930. Urgent please help!!!
Over the winter on a nice day, I decided to start up my car and let it run for a little bit. She started up with no problem and when I took it out of the garage and got out of the car, it just died. So I got back into it and tried starting it back up but would not turn over. The battery has plenty of juice and can hear the fuel pump kick on. It's just weird that she started right up and then out of nowhere just stalled out. What could it be? Any help would be great cause I am dying to take her out with this beautiful weather finally back. Thanks.
Well sounds electrical.. Does it try to turn over ? First thing I'd do is check the voltage on the starter and solenoid.. Could be a connection. Rarely does a car stop then not turn over, those are two seperate issues
Todd PS it's customary to post a pic (even of a car that doesn't run!).. Year and mods would help too! |
the car cranks, it's just seems like it's starving for fuel but I checked the fuse and relay and the voltage is good and the fuse has continuity.
If your fuel pumps are running then it seems unlikely that your starving for fuel during the starting phase.
Do you have spark? |
yeah I have spark. It just seems like a fuel problem cause it started no problem, ran for about a minute then died. Now it has a strong crank but won't turn over.
not being mean, but does the car have gas in it? you mentioned it has been sitting.
Haha... Yeah it does have fuel but I was having a problem with my lawnmower not running but come to find out, it had no fuel. I felt like an idiot but glad that's all set. Now just gotta get the car goin.
Ok so you have spark (meaning you've pulled a plug and have seen it right ?).
And it turns over when you crank it. Next I would make sure that there's no vacuum leaks redily evident ,, My car often won't start if the hose that connects the wastegate to the intercooler is off ( a common one). The next thing I'd do is remove the air filter so you can push the throttle metering plate down That will start the pumps and essentially "prime" the system. Do that for a few seconds and see if it starts.. If not, check a spark plug it should be wet from gas,, 99.9% of the time it's either gas or spark.. |
just for a quick once over 1) key on, air filter off, push down on plunger... hear fuel pumps? 2) pull plug wire from plug, stick long screw driver into plug boot and lay across something metal and grounded, have friend crank engine while you check for spark 3) pop the dizzy cap off, have same friend crank engine and make sure the rotor is turning |
Make sure both fuel pumps are running.
Check the red fuel pump relays in the front. |
Alright I'm gonna take a look tomorrow and hopefully I can get some answers.
This happened to me once and a friend rotate the long skinny fuse (not the round one) that use for fuel pumps and the car started right up. Maybe it is too simple but might as well try it.
Sounds to me like an ignition issue (do you have a Permatune in there or the Bosch unit???), but if that was it, you wouldn't be seeing spark going to the coil. Might be worth double-checking this.
T |
That happen to me Check ground on the lft side eng. by fuel filter. Don't know what # ground point that is.
It sounds like a gummed up plunger to me, ask me how I know... not a big deal to take it apart, clean it and put it back on.
Alright so I thought I had a good spark but had someone else take a look and told me that the spark is very weak. It's a hot enough spark, it's white but will not spark until it's practically held up to the grounded surface, so now what could that be?
| All times are GMT -8. The time now is 01:52 PM. |
