930 twin turbo muffler ideas
Going to go with Twins on my 930. Going to use 993 NA heat exchangers. anybody have any Ideas about ways to muffle this thing. I do drive this thing quite a bit so I think twin zorks might get a bit old. (Or i'm I getting old?) pictures please. Thanks guys.
Old 04-19-2010, 10:27 PM
E-85 sippin drunk
turbobrat930's Avatar
Yea, you are getting old!! HAHA I wish I could help you, but if I would have gone with twins on my build...I would have went straight Zork... just like I have with the single turbo....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 04-19-2010, 11:15 PM
Navin Johnson
TimT's Avatar
We used dual magnaflows, and some custom pipework
'69 911 GT-5
'75 914 GT-3
and others
Old 04-20-2010, 06:56 AM
3 restos WIP = psycho
kenikh's Avatar
Why not just use a factory 993TT exhaust w/ test pipe to omit the cats?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-20-2010, 08:04 AM
From what I have been told the oil tank is in the way and I don't want to move it.
Old 04-20-2010, 08:40 AM
930gt-40r's Avatar
You should talk to Glenn (purplehaze) about this issue- he has Protomotive car that he and I extensively modified on top of the original platform. He has twin 30r's on his car and he had the tank modified to fit the turbos in there. Its still a squeeze, but they fit.
Tim, that setup is simply awesome- i like
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 04-20-2010, 09:33 AM
Crotchety Old Bastard
RarlyL8's Avatar
You might eleminate those tight 180* bends by plugging the muffler in after the 90* and exiting the tailpipes just behind the rear tires.
Old 04-20-2010, 09:45 AM
This dose not solve the turbo fouling the oil tank. Saw one pic where they notched to tank.
Muffler could be something like this or stacked straight through mufflers. One high, one low.
Originally Posted by Bill Verburg View Post
Old 04-20-2010, 10:03 AM
Old 04-20-2010, 10:38 AM
RarlyL8's Avatar
N/A 993 exchangers will put the turbos close together out back, not on the sides of the engine.
If you mount the turbo outlets facing outboard then the exhaust can loop back 180* on both sides into short mufflers and exit with GT3 style tailpipes in the center of the rear. Kind of like the above picture.
Old 04-20-2010, 11:29 AM
The turbos will be fairly close together not clear of to the sides.
Old 04-20-2010, 11:49 AM
Navin Johnson
TimT's Avatar
The customer said nein in that case.
'69 911 GT-5
'75 914 GT-3
and others
Old 04-20-2010, 12:17 PM
Missed it was NA and not 993TT exchangers.
Why go twin turbo then? These work very well for a single turbo set up with Brian/Ben's Y pipe.
I think the 993NA's put the turbos very close together. Maybe to close to fit the exhaust between them as a Zork or a 180 but not sure.
Think I have seen twin's done this way but the turbo intakes faced each other and adjoined in the center and became a single charge tube went up to the intercooler (with two elbo's). The turbos exited outward on both sides which sould give room for a short muffler on each before exiting out the sides. I think Gemballa or someone did this many years ago.
Old 04-20-2010, 12:40 PM
I'm. Using twins because I have two turbonetics ball bearing turbos couldn't pass on the price. Oh! And there is the that's cool factor.
Old 04-20-2010, 12:48 PM
Maybe something like this but with the turbos closer together.
With the turbos closer together there may be room for mufflers to the outside.
Originally Posted by TurboKraft View Post
Old 04-20-2010, 12:52 PM
Another pic w turbo intakes facing.
Originally Posted by juicersr View Post
Old 04-20-2010, 12:58 PM
Thanks for all the pictures! Keep them ideas and pictures coming!
Old 04-20-2010, 01:02 PM
A light weight stainless turbine housing Gt35 or such from Tial is pretty cool to.
Still, sounds like a fun project.
Old 04-20-2010, 01:04 PM
TurboKraft's Avatar
930 Twin Turbo muffler
Hi,
Fitting a 993 Twin Turbo header system with turbochargers into a 930 chassis is really simple if you modify the stock oil tank. And this is easier than it sounds:
* tilt the tank outwards a few degrees, about 1.5" farther out at the base
* change the outlet port to the front edge of the tank -- a time consuming but straight-forward cut & weld job to modify
We further modifying the pickup tube and add internal baffling to help pickup oil liquid from the bottom and never run dry under cornering. Maybe overkill, but the old "while we're there..." applies.
We can do yours if you so need.
Before modifying:
After modifying:
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-20-2010, 04:05 PM
TurboKraft's Avatar
And with the turbos side-mounted, you can run a simple 2.5" dual in / dual out "X" muffler and the outlets will come out in the stock left & right locations. It's quiet enough for daily use, and flows plenty of exhaust -- 657awhp enough airflow for you?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 04-20-2010, 04:13 PM
