Delayed Ignition Cut-Off Relay
While getting my car running again and finding out I couldn't run without the Delayed Ignition Cut-Off Relay, I started to think it might be good idea to carry a spare one of those in the car along with spare fuses, relays, etc. Mine has a 1987 date stamped on it, so it's getting long in the tooth.
Then I started thinking, what if I bypassed it? I'm not even sure it was working before with the MSD, as it never seems to run on for a second after shutting it down. I realize it's to burn any left over gas in the cylinders, but what's the long term effect? I know Porsche wouldn't have installed it for grins. On another note, can it be jumped like the other relays in an emergency? |
Net-net, who needs it to start with? I suppose that old injectors might be prone to leak down into the cylinders over time, but I figure it just gives a nice pool of raw gas sitting in the heads or on top of the pistons to aid in starting!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I didn't even know to wire mine into the power source from the relay output. Did you change yours when you found it?
A few seconds of running isn't going to help a leaky injector I would think. It would burn what's there, stop and then continue to leak. How much was a new relay BtW? |
7.0:1 > 11.3:1 > 7.0:1
The delay relay has a small capacitor across it's coil input legs. When the key switch is turned to "on" the relay coil is energized via the light gauge red/black wire. Upon shutdown with the key switch this capacitor continues to feed power to the relay coil which in turn keeps the relay contacts closed thereby continuing to feed power to the CDI until the capacitor discharges. Very simple.
I've been under the impression it's intention is to run the motor until the pressure in the fuel accumulator drops off so the injectors don't drip after shutdown. You certainly can jump it if needed. Long term effect? who knows. |
Thats good information about how the delay relay works.
The MSD has a thick red wire for it's voltage amplifier and storage caps and a smaller red wire for turning it on and off. The thick red power wire is good to wire to the + terminal of the starter motor with a fuse inline. If you have the MSD on the firewall the starter motor is about a foot away. The smaller red wire turns the MSD on. If you plug it into the terminal in the 6 pin plug in the factory harness that also turned on the origonal CDI than the MSD will be going through the delay relay circuit. Or if you want to bypass the delay relay you could run a wire to the MSD from a fuse that is powered on at the front fuse panel with the ignition switch or from the ignition switch with or without a seperate relay. You could probably just modify the wiring at the delay relay socket to bypass it's effect too. |
I have my thick red wire hooked up at the starter. No fuse, as I don't recall it calling for one. Next time I'll run it to the battery.
The thin red wire is plugged into the 6 pin CDI plug. Quote:
I wired in my Crane HI-6n with the relay in mind. Does this relay control the fuel pumps at all? I'm trying to trouble shoot a problem.
Thanks, John
John- 78 Slick Top 930 "Illegitimi non carborundum" |
sudo apt-get purge 930
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
