I mis-interpreted your post and thought you were referring to higher resolution than 60 minus 2 which I am familiar with. Thanks for replying. Jim |
I am also curious what about the influence of RPM on twin plug timing variance from single plug. Is this plus or minus? |
911st,
More boost, less timing. A reasonable place to start is 20 degrees at 1 bar. The most noticeable benefit from twin plug is improved torque. Top end power is about right at 3% to 5%. Every engine is a little different. Give me a call about the timing curve, 310-406-8788 M-F 9-4 PT. I need some more information. Richard. |
| All times are GMT -8. The time now is 04:31 AM. |
