j930's Avatar
84 930 turbo vent slats
I noticed yesterday that one of the slats on side intakes is cracked,Its one of the three black louvers that are either side of the car right in front of the wheel. looking for a supplier and if any one here has taken them off before. thanks for any input.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 12-11-2010, 11:53 AM
Forced Induction Junkie
WERK I's Avatar
If it's a factory slant, the slats are held in place by two wood screws per slat. They are located in the inner wheel well. To remove slats, CAREFULLY unscrew. On the opposite side of the slat, there are two locating pins with a plastic sleeve on each to locate the slat in its proper orientation to the brake duct panel. Remove the top slat followed by the second, followed by the third. To reinstall, reverse the procedure.
The slants' slats are composite, so you may able to fill, sand and repaint the slats while they're out.
P.S. You may have to remove the wheel to access the screws properly.
Good luck
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-11-2010, 01:53 PM
DP935 member
kycarguy 935's Avatar
If it is factory please take some pictures of the inside so we can see if it is wood or plastic. There has been some debate about this before.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 12-11-2010, 04:17 PM
89 930.
Benny771's Avatar
Mine was a odd looking plastic(on the outside) black in color with a foam center orangeish in color.
Kinda looked like a Crunchy bar........MMMmmmmm.
I hear they are hard to get. I have seen wood ones for sale.
Old 12-11-2010, 07:49 PM
j930's Avatar
ok when I pull it out I will snap some pics, I do see the screws so I will CAREFULLY unscrew them. I guess I need to find some replacements. I will start with porsche and see whats available. I don't think its wood as they would have warped and split along time ago.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 12-12-2010, 09:11 AM
78scslantnose
78SCSLANTNOSE's Avatar
j930 I have a set off original quarter panels.Let me know if your interested as I'm not putting them back on.Here's a pic of the quarter panel.
Old 12-12-2010, 11:28 AM
j930's Avatar
I am thinking I will be refurbishing my broken slat. Porsche wants 280.00 for the slat, come on?
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 12-13-2010, 05:02 PM
930s slats
i have a set of six metal aftermarket slats. i was going to list them with other random parts for sale , but if these are of interest to you pm me and i am sure we can work something out. my car is gone. im sorting out a new one (1987). kevin
Old 12-13-2010, 06:11 PM
DP935 member
j930, In the past I have made a few pairs. I had the plastic and made a pattern and cut, ground and sanded until they were perfect. I am sure you could do the same using the broken one as a pattern.
Good luck.
Old 12-14-2010, 11:48 AM
j930's Avatar
thats a good call
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 12-14-2010, 03:27 PM
