Fuel nozzle flow test 930-78-3,3
I'm going to do a flow test on the fuel nozzle, to see if the distributor head is okay, my fuel nozzle is brand new and has also been checked to be sure they were 100% okay.
How much volume they give piece per minute, with flow sheet fully depressed
Regards John
Old 06-18-2011, 01:55 PM
jsveb's Avatar
Hi
I don't know what research or knowledge you have regarding this, but there are a couple of test that should be performed prior to doing this one.
I have done most of them. I am a rookie in this game, but made it - I think.
You can read this thread to get an idea of how to go about it. Please read the threads by Thierry and Stup. They are way ahead of me.
CIS injector flow testing
Good luck.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 06-18-2011, 05:55 PM
Hello.
I have now read through the articles and can not see anywhere how much volume they have to give.
greeting
John
Old 06-19-2011, 12:23 PM
jsveb's Avatar
Hi
Remember, as I mentioned there are a cuople of test to perform before doing the injector test. One of them is checking the fuel delivery for the control pressure circuit.
I don't remember all these tests, but
Once you
Have done them. I think what you want to check is the " crack" pressure ie the pressure at which the injectors open. Then the spray pattern and very important that the injectors deliver The same amount.
This was a brief iPhone answer...
Old 06-19-2011, 12:39 PM
Alan L's Avatar
Fuel pump total flow 1.1 litres/30 seconds - both pumps going.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-19-2011, 04:45 PM
