Correct Helper Spring Orientation
Want to make sure this is the correct way before I put it back in the car. Also how do you "snap" or "load" the spring?
http://forums.pelicanparts.com/uploa...1274835948.jpg |
This thread might help:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/464159-help-omega-spring.html |
I used a big visegrip to preload.
Just wanted to make sure the spring is in the correct spot before I mate the trans to the clutch. I will then "load" it. As long as you guys think it looks good so far. THX!!!
Hook up the trans to the engine and then get the arm/spring ready. In fact, I don't install it until the engine is installed and I'm under the car hooking everything up.
| All times are GMT -8. The time now is 04:14 AM. |
