will this work? (oil cooler in series)
wts: BAT / mocal oil cooler
Will this work if I mount as a front oil cooler in series with my current B&B fender mount? Or, am I better off buying the typical 70+ row mocal (for $575) and running that alone? (and selling my current fender cooler) In other words, is there an advantage to running two separate smaller coolers rather than one larger one? (other than the net ~$250 in cost) Thanks,
Vic '79 930 '97 Miata M edition missing my Tony//Kart 125cc shifterkart |
That's a pretty small oil cooler and unless you have a way to get air to it (an air dam), it's going to do minimal cooling IMHO. Might be better off moving it to the other fender, blocking and adding a fan. Two big coolers is what I would do.
Depending on what you do with the car, i.e track it, hot weather, stop and go traffic, etc., extra cooling is a must. Especially if you are making any more power than stock. I had the stock fender oil cooler with a large air dam oil cooler that worked great. Never got over 200-210 at the track in hot weather. Since removing my air dam, I'm looking for ways to remount the same cooler in the left fender well. It's too big to mount behind the stock valance unless I do major surgery to it (and I don't have those skills to make it look good). |
Stranger on the Internet
I have tested this before, and find that the pressure drop is excessive with two coolers in series. The scavenge pump cannot pump through them adequately.
Pat
Patrick E. Keefe 78 SC |
thanks guys. I'll plan for a single larger cooler.....
Wo ist die Rennstrecke?
I run two large fluidyne coolers in series with no pressure drop issues. I use -12 lines too. One cooler is a single pass and the other is a dual pass. Look at fluidyne's website for pressure drop numbers. I think mine drops 6 psi for both. For high performance, two coolers is an important upgrade.
My 930 has two oil cooler also with fans behind each cooler. One cooler is in each fenders with ducts from fog light openings (fog lights are removed). This setup is without an engine mounted oil cooler. It maintains at least 1.5 bar at idle. -12 lines are used, too. So I don't see a problem using two oil coolers.
Are the oil pumps the same for all year 930's? Mine is an '87.
MikeD '87 930 |
