Engine problem 930 78 3,3
Hello. When engine is hot and has been off for approx. 45 minutes. Start it badly. it is as though drowning. First I thought it was fuel shortages and changed a whole lot of parts it did not help but think now that it drowns. What can I do about the problem ???
Regards john
Old 08-08-2010, 10:33 AM
beancounter
jwasbury's Avatar
Assume you are running the stock CIS? Hot start issues seem to usually be traceable to a bad fuel accumulator or check-valve at the front fuel pump. You say that you've replaced a lot of parts already...was the accumulator one of them?
Have you verified your hot/cold control pressures, operating system pressure and residual pressure? I'd check these things first. When you say its "drowning" I take that to mean you think its rich (too much fuel?). Maybe there is an issue with the cold start valve.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 08-08-2010, 10:59 AM
totle's Avatar
Had same problem on my 78 930 last year.
I replaced fuel accumulator and have never had this problem since
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 08-09-2010, 10:35 AM
