Wastegate?? 930 3,3 -78
Hello. when I blow air oo-o.5 bar in the control line on the wastegate blows air out of vent pipes. must it? or is my Waste Gate Diaphragm leaking?
Sincerely, john |
Happiest when Tinkering
leaking
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Hello. I have now separated wastegate and have doubts about washers di / sims should be there. or they have been retrofitted?
Regards john ![]()
Shims need to be there so spring doesn't wear into aluminum.
Thanks for a great help.
![]() john |
Your welcome
If it leaks constantly or doesn't hold pressure, you're right = leaking. And that is most probably what it is.
But, if it holds pressure, even at a low level, and then discharges it could be a worn out spring. So, when rebuilding the diaphram get a new spring JIC. |
Hello again. just one last question. the veil / sloop in the shaft / bushing, how much needs to be and should I lubricate it with copper grease
Regards john
I am not sure but it should be along the lines of if you can feel it then there is too much slop, I would take it to a machine shop and check the runout and then press in a new guide and ream/fit it.
