Blitzkrieg
jly535's Avatar
Power Bleeding gone bad!
So my brakes suck 77' 930! I know they're not supposed too be great, but they're worse then my 1st car 62' bug.
I decided to power bleed them today. Well after hooking it up and pumping up the pressure (10psi) i hear fluid leakin. I look under the car and there is a huge puddle of brake fluid.
It was dripping from around the steering rack and also flowing down by the battery area. My first thought was the MC or booster was leaking, but they seemed clean.
Any suggestions?
77' 930
10' BMW F800GS
08' Tundra
Old 10-06-2010, 05:57 PM
did you plug the breather line on the reservoir?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-06-2010, 06:03 PM
Jeff Alton's Avatar
Yep, clamp of the breather tube that exits the resivoir.....
www.turn3autosport.com
Old 10-06-2010, 06:05 PM
Blitzkrieg
jly535's Avatar
UM, no. I've been think about that (I'm at work) so wasn't sure about that line.
Thanks,
Will be re-trying tomorrow.
77' 930
10' BMW F800GS
08' Tundra
Old 10-06-2010, 06:07 PM
Non User
infraredcalvin's Avatar
++++1
I did the same thing not thinking about it. It's the clear hose that connects to the side of the filler.
I used a small length of hose with a golf tee shoved in it.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 10-06-2010, 06:08 PM
Blitzkrieg
jly535's Avatar
Thanks guys! Lesson learned. At least the trunk got cleaned after I flushed it with water.
Round II tomorrow.
77' 930
10' BMW F800GS
08' Tundra
Old 10-06-2010, 06:38 PM
Blitzkrieg
jly535's Avatar
^ Can these jersey's soak up a lot of brake fluid?
77' 930
10' BMW F800GS
08' Tundra
Old 10-06-2010, 10:08 PM
A930Rocket's Avatar
+1 I did the same thing the first time. Tried to bleed the brakes. No luck. Walked around front and it looks like the Exxon Valdez under the left front. Doh! I use a pair of needle nose vice grips to clamp it off now.
Last edited by A930Rocket; 10-07-2010 at 07:44 AM.. Reason: Lack of command of the english langauge..
Old 10-07-2010, 02:51 AM
wcc wcc is offline
wcc's Avatar
Yup, I've done it too. But mine did't get fluid all in the trunk and battery area. It drained out of the hose and made huge puddle under the car. I would check or replace that hose if it leaked all over inside.
Bill
997.2
Old 10-07-2010, 03:04 AM
IMR-Merlin's Avatar
Just want to add something I learn recently. To clean up brake fluid, all you need is water. I learned this on a stunt forum and didn't believe it until I tried it. So, the next time you get brake fluid on anything you care about, just hose it off. No need to use any harsh chemicals.
Old 10-07-2010, 04:21 AM
Ken911's Avatar
OK so is there any one here who didnt do the same thing at least once? LOL certainly not me the real pain was driving to coral gables to get more brake fluid that day.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-07-2010, 04:45 AM
lol... first time I did it too. I could hear the sssss of air leaking by the left front wheel, looked down there and had a puddle of brake fluid on the ground and saw the end of the little nylon tube from the brake fluid container above it.
Old 10-07-2010, 08:32 AM
cycling has-been
bkreigsr's Avatar
can I play?
Help with Power-motive brake fluid change
Old 10-07-2010, 10:08 AM
