Help Front brakes ... unknown rotors!
Hello Guys,
The Turbo is in the shop for some mild upgrades prior to me returning home. I asked to have the brakes checked. Much to my dismay the front rotors need replacement! Now, .... this is a problem as the car is fitted with a fully floating rotor / hat assembly and big reds! The shop cannot seem to figure out what rotors these are and how to find / order another set. So, ... the car is just sitting!
The rotor is ~ 322mm OD and 32mm thick. It is a 12 bolt. I have been told its a race brembo, maybe?
nobody can seem to figure out what to order and from where. Can anyone on here help?
Last option is a full replacement of the front rotor / hat with another adapter for the caliper! This is ugly, but .... I want to drive! Can anyone recommend a good kit? Floating is prefered, but ... maybe not needed with my driving.
Thanks Chris
Old 07-14-2016, 08:00 AM
It could be several different combinations of rotors and hats.
We need a few pics and I'm sure somebody would recognize them.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 07-14-2016, 10:03 AM
You could call Vehicle Craft to see if they could help you out. They have many brake kits with many rotor size options.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 07-14-2016, 01:10 PM
Scottsdale Arizona USA
Hey Chris, you could use some 993TT (10 Bolt) front rotors. They would be the proper and available set. Cost is currently ~195 each range for the German reproductions. These feature a removable hat you would then retrofit with the MODE billet adapter hats which cost about ~550 set (in stock). These have the proper offset for the 82- turbo hubs. Another option would be a Girodisc brand which come in a slotted rotor and typically last longer.. you would order without hats. Let me know if you need some help on this one.
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // mode@europartswest.com
Old 07-17-2016, 12:23 AM
Appears they might be Colemen rotors ...
Anyhow, I pulled the trigger on a Patrick racing set up ... 993 TT rotors and 10 bolt hats..
thought about an Alcon set up, nice!!!
Old 07-24-2016, 05:06 PM
