MikeD930's Avatar
Originally Posted by IMR-Merlin View Post
There is a real simple solution for this and we use it in race cars to get the tires off the ground quicker in pit stops, you just have limit straps that will limit the droop of the suspension.
That's exactly what I did when I replaced the JRZ front struts (to be rebuilt later) with Bilsteins RSR Sport coil overs. See pic below:
Originally Posted by jimtweet View Post
that is the thing, i want to do away with torsion bars all together, and i am being told that with such a low spring rate and no track time, the bracing isnt something i need to worry about
My '87 930 has coil overs all around using 600/250 rears and 400/150 fronts. Also, my car does not have any bracing on the rear shock towers that I can see. Mine must be an earlier '87 and bracing perhaps was added on later '87. I may be wrong. Anyway, my car was heavily tracked by previous owners. I checked for any cracks and found none.
MikeD '87 930
Old 10-19-2010, 01:20 PM
any chance you can take a pic of your rear towers for me? thank you so much for your response and any help you can offer
Old 10-19-2010, 02:56 PM
MikeD930's Avatar
Sure, here's a couple.
Close up shot
MikeD '87 930
Old 10-19-2010, 03:09 PM
Close up shot
thank you so much
Old 10-19-2010, 04:03 PM
IMR-Merlin's Avatar
Thanks Mike, that was exactly what I was talking about..
Old 10-19-2010, 04:37 PM
Navin Johnson
TimT's Avatar
The worst thing that can happen if you don't reinforce the shock towers is that you punch a shock through... Then you get to re-weld and reinforce..
BTW I think 325# rear springs will really disappoint you, the rear end will squat like a dog dragging his butt along the carpet..
If you get all the friction out of the rear suspension, you can run some fairly stiff springs on the street and still have a nice ride..
As a comparison my track only racecar with 935 suspension components weighs 1850# wet.. I run 400# and 600# springs on it... and think increasing the spring rate will be in my future..
'69 911 GT-5
'75 914 GT-3
and others
Old 10-19-2010, 05:36 PM
anyone else with coils and no bracing?
Old 10-21-2010, 04:19 AM
proffighter's Avatar
No. I did not reinforced and had some cracks at the outside of chassis and the whole tower will get loose, welding points will fail. And mine is only street use:
I highly recommend to add reinforcements and add some welds at the tower!
Roland
930 Turbo '81 Too many modifications to list
Old 10-21-2010, 05:08 AM
Blackbird Pilot
Reaper930's Avatar
Go with Clint at rebel racing...i'm running 450 lbs springs up front, 850's in the rear valved accordingly with 19mm raised spindles on the front. Its the way to go.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 10-27-2010, 12:18 PM
Blackbird Pilot
Reaper930's Avatar
BTW clint sells a weld in brace for the rear towers that is premade to fit the stock towers perfectly.
Old 10-27-2010, 12:19 PM
Reaper,
Just wondering, why not 35mm or more?
You should have the room with your rims.
Is there a limit on different types of struts as to how much they can move them?
I am guessing you lowered your front more than 19mm but I could be wrong.
More also gets you a more agressive camber curve, though with almost 4 times the stock front spring rate you probably do not see much deflection when cornering.
Just wondering.
Thx.
Old 10-27-2010, 05:15 PM
Blackbird Pilot
Reaper930's Avatar
I raised them 19mm as this put the front suspension in perfect geometry in combination with the 17" wheels and tires I am running. The front of my car really isn't much lower than a euro 930.
Old 10-28-2010, 08:51 AM
Thx!
Old 10-28-2010, 09:44 AM
Got Boost?
I have a set of RSR coils on my car
I believe spring rates are 300/450
Originally I had these on a 79 SC targa- no reinforcements- no issues
I did reinforce my 930 rear subframe because car will be 90% track and am thinking of giong to 800 ish rear spring rate
Not to hijack but has anyone changed the way the top of the shock mounts in the car ? ( Clevis type )
john bradshaw
comscc.com
porsche 930rs
SPA #227
Old 10-28-2010, 11:03 AM
Blackbird Pilot
Reaper930's Avatar
Before I tied my rear suspension into the cage I didn't reinforce when I ran only rear coils however, it was only for 3k miles. Clint at Rebel wouldn't sell a shock tower brace if it wasn't needed. If you're going for 800 lbs rears and valved right, I would reinforce as my 850 lbs coils and custom valved Rebel coils are STIFF but my car only weights 2,000 lbs so YMMV.
Old 10-28-2010, 12:26 PM
subscribe
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 04-17-2012, 10:54 PM
