-   -   Intercooler temp before and after (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/571072-intercooler-temp-before-after.html)
WANNA930 10-21-2010 06:01 PM
Ok I have a 77 without intercooler before someone says why not just buy an intercooler.
Anyway, new to the turbo deal and have a few questions after reading some of the recent posts on water to air or meth/water injection.
I know different engine set ups will produce different intake air temps. The questions I have are:
1. What is a base temp of before the IC and after the IC.
2. What is the temp after with an aftermarket IC. I know they will vary with size and make. How much of a difference do they make?
The idea behind an intercooler is to provide a cooler denser air correct? I know there is math and different flow involved with different designs. What i am getting at is if it is possible with using meth/water or wet IC or a combo of both to produce the same results??
The water/meth is something that has to be added regularly but so does gas.
What am I missing here?? Wouldn't it also provide a less restrictive air flow from turbo to intake??? How would this effect boost?
Thanks and sorry for the somewhat basic question. Just trying to pull a couple posts together to where I can get a clear understanding and game plan as to how I want to plan my set up. I have a strong mech background and understand that mods only work when other mods are done. I just want to keep my stock tail and sort of hide all my performance additions as best I can.
spuggy 10-22-2010 07:42 AM
The only I/C comparison figures I've ever found are on Kokelyn's web site intercooler. The figures speak for themselves.
drmatera 10-22-2010 08:27 AM
Those numbers are very similar to what I found while running my car with no intercooler. I would regularly see temps above 200* on boost.
Now, the question is where did they take the outlet temp from? Off the actual intercooler or in the intake manifold. My sensor is in the intake manifold and I see 125-130* temps on 80*f + days with the intercooler installed. So roughly 100* is being removed by the intercooler.
Now I also ran WMI on my turbocharged 5.0 mustang before ever putting an intercooler on it. I was seing 80*-90* temp drops when the WMI came on, I was seeing 150* inlet temps in the intake.
Once the intercooler was installed:
On a 1/4 mile pass my inlet temps would start at 120* (170* engine temp), by the end of the pass my inlet temps would be just over 100*. If you were going to choose just one of the 2 options and didn't mind filling the jug I would go right to the WMI and keep your wing. But there was a benefit to running both
mppickett 10-22-2010 06:32 PM
I've only run a full bay intercooler on my turbo, but I ran both a water-air and water-meth injection on another car. I'm pretty handy and tried many different setups for water-air, but I was never really happy with the reliability or resistance to heat soak problems. I had very good results with water-meth injection.
All approaches have pros and cons. The water-meth is great for reducing the throttled air mass (improves responsiveness). Water-air is compact but the plumbing is complicated. Air-air has more throttled air mass than the other two (usually) but can be very effective with very little complexity.
If I was trying to keep the stock engine lid, I'd go for water-meth.
WANNA930 10-22-2010 06:59 PM
That is what I am leaning towards but I have never used set up before. I just can't see it being as effective as an intercooler but for the investment and ease of install what the heck.
I am surprised that it actually would decrease temps that close to an intercooler. I wonder how much cooler than say a stock intercooler? Also does the benefit of no pressure loss through the cooler make it even more effective? The only shortfall is filing up but then with say a 2 gallon tank it would be near a tank of gas with a electronic mgt.
Why is everybody paying $2500-$3000 for intercoolers??
turbobrat930 10-22-2010 07:58 PM
I dont know... I paid just under $1400 for mine... new, shipped to my door, full width I/C... If you want a bolt up, I/C and still use your A/C....then you will have to pay the price....
911st 10-22-2010 08:04 PM
subd
RarlyL8 10-23-2010 07:06 AM
An intercooler to fit a '77 deck lid would be custom which is where the expense comes in. My bolt-on for the '78-on is in line with the pricing Brad quoted.
If you are relying on some sort of charge air cooling to safely run the engine on boost a properly set up intercooler is worry free. No fluid maintenance or electricals/pumps to fail. If the charge air cooling is just for free HP that issue goes away.
gsmith660 10-23-2010 09:23 AM
Dont write off the power of latent heat of vaporisation of water I think you get a better cooling effect from WMI than a intercooler both in combo is better I will do some testing when I get WMI install and the charge temp gauge and I found a place that has intercoolers similar to mine in various sizes for 3-400 dollars the prices you see are the porsche markup on these parts.
