-   -   getting engine up on engine stand (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/575695-getting-engine-up-engine-stand.html)
fredmeister 11-17-2010 09:19 AM
How do most of you guys lift the engine onto the engine stand? I ask because I dont own a hoist.
Just have a floor jack and dont want to buy a hoist for 1 job.
A930Rocket 11-17-2010 10:20 AM
I had some friends help me after installing the engine mount. Just lifted it up and inserted it into the stand. Of course, anything y ou can remove to lighten the load helps.
Next would be renting a hoist.
torresmd 11-17-2010 12:48 PM
2 or 3 other guys and just bear hug it. It is not that bad.
axl911 11-17-2010 12:57 PM
Oh that is easy. Just build a wooden blocks to support your jack or motorcycle jack which you used to rest the engine on. You can then raise it to the height of your engine stand, and slip the engine stand in between the blocks.
See attached picture on how I built mine. I raised heavy ass 964/993 engine like this by myself and in relatively safety.http://forums.pelicanparts.com/uploa...1290027438.jpg
