replacing cam
I have sc cams in my car and one of the lobes is worn. I have to replace it.
I have two questions. Were can I find a good sc cam? I am thinking of doing the job myself.. I am very mechanically inclined. I have a shop I can do the work in. I just ordered Waynes book on rebuild. How much time should I be looking at to do this kind of job.. I was told I dont have to drop the whole motor out just drop it down.. What do you guys think. |
You don't have to drop the engine, but it would make it easier. EBS and Web Cams should be able to help you with new cams.
What Jim said.
I had the same issue with a C2 cam. Sent it to Web cam for repair. Should check the oil bar for a clog. |
slyguy the squirer was clogged that was fixed now its time to replace the cam.
Thanks guys |
| All times are GMT -8. The time now is 02:23 AM. |
