jbrown's Avatar
replacing cam
I have sc cams in my car and one of the lobes is worn. I have to replace it.
I have two questions. Were can I find a good sc cam?
I am thinking of doing the job myself.. I am very mechanically inclined. I have a shop I can do the work in. I just ordered Waynes book on rebuild. How much time should I be looking at to do this kind of job.. I was told I dont have to drop the whole motor out just drop it down.. What do you guys think.
Old 01-03-2011, 03:55 PM
A930Rocket's Avatar
You don't have to drop the engine, but it would make it easier. EBS and Web Cams should be able to help you with new cams.
Old 01-03-2011, 04:39 PM
What Jim said.
I had the same issue with a C2 cam. Sent it to Web cam for repair.
Should check the oil bar for a clog.
Old 01-03-2011, 07:14 PM
Originally Posted by 911st View Post
What Jim said.
And it is WAY easier to pull the spray bars with the engine out. Best check your rocker arms for funky wear as well
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 01-03-2011, 10:47 PM
jbrown's Avatar
slyguy the squirer was clogged that was fixed now its time to replace the cam.
Thanks guys
Old 01-04-2011, 01:33 PM
