Tilikum Turbo's Avatar
Insulation plate between KKK turbo and exhaust...
Has anyone seen one, or been recommended such a plate?
I was wondering what benefit the turbo might have being a little buffered
directly from some residual heat/ir, etc.
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 04-03-2011, 05:30 PM
Crotchety Old Bastard
RarlyL8's Avatar
Is it possibly the turbo support bracket your are referring to? It does look like a plate sandwiched by gaskets.
Old 04-03-2011, 05:52 PM
TT,
I have seen , what appears to be, heat shields used between the turbo and the engine, I have always assumed it was to keep excessive heat away from the engine and rear bodywork..
They were used a lot on 934's and here is a similar shield on a 993 GT2.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 04-03-2011, 10:10 PM
tj930's Avatar
Did the 993GT2 only have one turbocharger? (Bit of a surprise, that.)
Old 04-04-2011, 05:21 AM
Smart quod bastardus
fredmeister's Avatar
FYI, that single heat shield above the turbine housing reduces heat transfer by about 50% than without the shield. Its very effective and simple.
I found that there is next to no clearance between the k27S housing and my engine sheet metal in order to install one myself on my car. Its just too tight in there.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-04-2011, 07:18 AM
