Brando
bosch 044 fuel pump
This pump appropriate for the rear pump on a 930 conversion?
0 580 254 044 And a standard 77 911 pump for the front? |
Brando
Externally mounted, in line electric fuel pump. 300 LPH flow at 43.5 psi (3 bar) and 200 lph at 73.5 psi (5 bar). You can install this pump along with a high performance in tank pump or by itself and can support 700HP with the proper fuel lines
