Brando
boost tap
Hey I just got a boost gauge from north hollywood speedometer to replace my clock in my 77 911s. It's mechanical so I'll need to run a hose or tap into the brake booster line. Can I tap into the line to the brake booster and have vac/boost feed for my new gauge? Thanks
Brando
Very stock looking, love it.
After the next project
I had the same one. You need about 2 feet of hose. You will add a T fitting to tap in at your brake booster line (extremely tight in there) and then you are good to go. 30 minute job once you have your clock and line through the firewall.
Best of luck, Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Brando
Very cool, thanks
tee
any spec on the tee needed? Is it a barbed fitting, what size? Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Brando
I've searched this topic. It appears that taping into the brake booster can be problematic with accuracy. I don't know why bit would guess that the size of line to the brake booster and possibly old rubber to be the cause. I'm just going to run a line to the intake manifold. Harder, but more safe.
location, location
Like they say, location is everything. I have the same job to do. Post a pic if you can when your done. thanks Philip
Crotchety Old Bastard
Mine is run back through the tunnel to the BOV housing. I know it is commonly done but I am really uncomfortable cutting the brake booster line. If there is anything I don't want to worry about that's gotta be it.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Brando
I stopped the when I saw that the line was way larger than I thought it would be. I expected that I could get a little "T" and splice it. Not so, so I started poking around pelican and found that it's sometimes not accurate. And the tap into the brake booster seems a little poky anyway. It sucks that I'll have to run the line all the way back, but it'll be worth it.
If you look under the front tunnel carpet where the tunnel meets the firewall there is an opening, there's one at the shifter, and one under the coupling cover where the rear of the tunnel meets the rear floor bulkhead. Fish a wire from back to front, tape some vacuum hose to your wire and pull the wire with the hose back through the tunnel. Do not cut holes in the tunnel, the fuel lines are in there !!!!.
Tie into the Boost Gage and then T the other end into the boost line that goes to the bottom port of the wastegate. You'll need two fittings (1) npt to hose barb for fitting on the back of the boost gage and a plastic barb T hose will work fine at the wastegate line. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 02-21-2011 at 02:41 PM.. |
