Ruf clutch cable for 86 930
Replacing the clutch cable in my 86 930 which has a Ruf 5-speed. Apparently this may be a special length cable since the one I ordered from Pelican is about 1.5 inches to short.
Anyone else out there with a Ruf 5-speed that has BTDT?
Thanks....
Drew
(Have e-mailed Ruf in Michigan, but it's the weekend...might as well get some research in)
Drew
86 930
Old 02-18-2011, 07:58 PM
On the pre 1978 Porsche 930 cars the bellhousing is about 1 1/2 inches shorter than the later cars due to the change from the 935 style clutch package to the rubber style to eliminate clutch chatter from non experienced type of drivers usage of these cars. Are you sure you recieved/orderded the cable for the later car if there is a difference?
Anthony @ Voitureltd Bayside WI.
Old 02-19-2011, 08:09 AM
Sending this one back...might have to wait for Ruf to get back to me on this one. Had a private e-mail that stated the Ruf might need a 76 turbo cable, but when you look at the pic it has no hooked end which mine has.
Drew
86 930
Old 02-19-2011, 08:08 PM
totle's Avatar
Have you checked if the 89' 930 cable will fit? That had has a G50/50 5 speed transmission.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-20-2011, 05:17 AM
TURBO TALES's Avatar
[QUOTE=totle;5857342]Have you checked if the 89' 930 cable will fit? That had has a G50/50 5 speed transmission.[/QUOTE
Just to let you know the 89 G50 has a hydraulic clutch and has no cable.
88-930 Black / Tan
89-930 Grand Prix Wht
70 Trans Am Ram Air III 4 speed
74 Bronco Sport 302 Auto Beach truck for the Mutts
Old 02-20-2011, 05:29 AM
Found the part! Here's some info for the archives:
Clutch cable, 930 5 spd
Item #R30 423 401 01
Sourced from Ruf in Southfield, Mi 48075
248-304-9091
Drew
96 930
Drew
86 930
Old 02-23-2011, 02:07 PM
