Info on 930 turbo required
Can anyone tell me how many 1987/88 turbo 930 cabrioletes were made
Old 03-13-2011, 06:59 PM
1987
ROW 142
USA 87
1988
ROW 242
USA/Canada 282
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 03-14-2011, 09:07 AM
Jerry S's Avatar
Hello Cole 930,
I apologize about the sideways question, but I notice your "handle" suggets that you have a reduced ring and pinions for 2nd and 3rd gears. Did this mod alone make a difference to your performance and did you notice a huge drop when going to 4 th ?
Mark
TURBO = Free Power
Old 03-14-2011, 05:38 PM
Mark.
There is only 1 ring and pinion, it determines the final drive ratio for all four gears and effects them equally. On a 930 this keeps your gear changes more in the sweet spots where the delay before generating torque in the next gear comes quicker. First gear in a 930 is very short anyway so you don't want a radical change in ring and pinion ratio.
I shifted from 3rd. to 4th. at 145 and have easily seen in excess of 160. I only drive my car on the street and there is no place to use all that top end safely so I choose to change the ring and pinion to make the car quicker in the lower gears and can still run 150 or so in 4th.
I choose to change 2nd and 3rd to dial in those two gears to a little less rpm drop after the shift was made from 1st. to 2nd. and from 2nd. to 3rd. There is a drop from 3rd. to 4th but it is not any worse than it was originaly.
The ring and pinion mod is defiantly not cheap but will make the most significant change in performance of any single mod you can do.
Cole
Old 03-14-2011, 06:58 PM
How many in US and how many in Canada?
Old 03-15-2011, 11:07 PM
