-   -   Adding a fan to my intercooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/598801-adding-fan-my-intercooler.html)
panel 03-24-2011 06:39 AM
Has anyone added a fan to their intercooler? What would be the best way if wanted?
1)on top and blowing?
2)on top and sucking?
3) underneath and blowing?
4)underneath and sucking?
I just don't want to run out of air or disturb the air flow if you know what I mean.
cole930 03-24-2011 08:50 AM
Panel !!!!
Take a look at the thread above: "Boost loss when hot"
Alan L 03-25-2011 03:00 PM
If you are going to do it, the logical answer is on top, blowing - you have room to fit it there and the airflow is in right direction.
Alan
equality72521 03-25-2011 03:39 PM
Alan
Pull through is always more efficient. That's why refrigeration systems use pull through. Room, as you point out, is the issue though.
David 03-25-2011 03:40 PM
When the cars moving, my intake temps cool off pretty fast when I get off the boost so it seems like there's good air flow without a fan.
spuggy 03-25-2011 04:25 PM
According to this thread http://forums.pelicanparts.com/porsche-911-technical-forum/170042-engine-fan-drive-ratio.html, the 3.2 fan moves 1500 litres/second. Over 3,100 cubic feet per minute.
Which, apparently, takes about 10HP. That would be a pretty substantial 12V motor.
So why not just make sure your engine bay seals are good like the factory intended, shroud/seal the I/C like the factory intended and use the very large fan you already have?
cole930 03-25-2011 04:49 PM
Panel,
Here you go Summit Racing:
http://forums.pelicanparts.com/uploa...1301096937.jpg
Cole
