Widest tyres on stock body!
Now i got 235/40-18 front and 295/30-18 rear and its plenty of space!
What is the widest combo that have been fitted to stock turbo body/fenders
in 15" ,16" ,18"
Intressted in tyrewith, rimwith and rim et front and back.
Best regards Stefan
Old 03-30-2011, 02:33 AM
I would think 11" - 12" rims under the stock turbo fenders without any spacers.
Old 03-30-2011, 02:41 AM
tj930's Avatar
Stefan, a quote like that demands that you show us a picture!
Old 03-30-2011, 03:45 AM
Action pic some years ago
Resent pic with 145/90-16 from flyingkilometer on ice RECORD 241.708 km/h averidge
Actually I´m offerd rim and tyres that is 15" 280mm front and 350mm rear seller claims it will fit but I got my doubts.
/Stefan
Old 03-30-2011, 04:33 AM
Crotchety Old Bastard
RarlyL8's Avatar
I ran 255/45-15 and 345/35-15 Yokos on 9&12x15 for years until the tires became NLA.
Old 03-30-2011, 05:08 AM
Sound promesing.
Almost same sizes as the combo i´m offerd do you remember ET at the rims and had you any issues with tyre rub?
/Stefan
Old 03-30-2011, 07:08 AM
RarlyL8's Avatar
The setup would not fit without modification:
- Euro ride hieght
- Cut fender lips off
- Moved oil lines on passenger's side
- Ground off alignment adjust bolts and half the nuts on swing arm
- Custom spacers for each side to locate wheel/tire perfectly
IMPORTANT NOTE - at 13.5" Yoko 345 tires are 3/4" wider than Pirelli 345 tires. Huge difference.
Old 03-30-2011, 08:28 AM
You certainly need the correct offset.I have a 335/35/15. I don't have rims yet
But from what I can measure it will fit.
Old 03-30-2011, 10:43 AM
