source for color coded wire
Ok so when i swap to efi I will be building my own wiring harness. Replacing a lot of the existing wire with new plus all the new stuff for EFI. Does anyone know where to get wire in the stock color codes listed in the service manual? Red with blue stripe white with brown etc.
Ken, you can also look at the Aircraft industry. Most wires are plain white, but every 12 inches there is a laser etched number or ID of your choosing... Then, you make your own wiring key, and then, add that to your service manual....
I know, not the answer you were requesting, but another option, none the less.... |
Racetronix - Wire - TXL - 20 Gauge EFI Connection - Item Details Cross-Link GXL Wire |
thanks!! this will help a lot
Prowire Prowire USA
http://forums.pelicanparts.com/uploa...1301849050.jpg
Let me know if you need sources for new contacts, connectors, etc. |
ok thanks
| All times are GMT -8. The time now is 08:37 AM. |
