Ken911's Avatar
source for color coded wire
Ok so when i swap to efi I will be building my own wiring harness. Replacing a lot of the existing wire with new plus all the new stuff for EFI. Does anyone know where to get wire in the stock color codes listed in the service manual? Red with blue stripe white with brown etc.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 04-03-2011, 08:12 AM
sudo apt-get purge 930
equality72521's Avatar
I used these guys and it was very good stuff.
Automotive Wires
--clutch-monkey
Old 04-03-2011, 08:27 AM
E-85 sippin drunk
turbobrat930's Avatar
Ken, you can also look at the Aircraft industry. Most wires are plain white, but every 12 inches there is a laser etched number or ID of your choosing... Then, you make your own wiring key, and then, add that to your service manual....
I know, not the answer you were requesting, but another option, none the less....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 04-03-2011, 08:56 AM
sjf911's Avatar
Automotive Wires
This is the only source I could find for metric wire with correct colors. I went with standard wire since you really aren't tying into the old wiring system much. I sourced from various places for the best deals. One thing I did was to buy 200ft of 20g TXL white then striped it myself with permanent markers. I also bought a fair amount of shorter sections of colored wire from EFIconnection after I had determined the wire lengths needed. In the end, at least with megasquirt, I would have been better off buying an off the shelf harness from DIYautotune as you got great colored wire a lot cheaper than I could build the harness myself buying bit pieces of wire.
Racetronix - Wire - TXL - 20 Gauge
EFI Connection - Item Details
Cross-Link GXL Wire
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 04-03-2011, 09:02 AM
Ken911's Avatar
thanks!! this will help a lot
2019 Silverado 6.2L
Old 04-03-2011, 09:20 AM
Prowire Prowire USA
Old 04-03-2011, 09:34 AM
Let me know if you need sources for new contacts, connectors, etc.
Old 04-03-2011, 09:45 AM
Ken911's Avatar
ok thanks
2019 Silverado 6.2L
Old 04-03-2011, 10:36 AM
