-   -   Custom Beru length-to-order ignition wires for 930/965 conversions (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/603074-custom-beru-length-order-ignition-wires-930-965-conversions.html)
MarkRobinson 04-15-2011 09:24 AM
Hi guys,
I sell my DIY Beru wire kits through PelicanParts, but also wanted to let everyone know that I also make 965 wire sets and made-to-order (lengths) 930/911/965 wire sets, so if you're using Tec3 coils or other coil packs for your EFI conversions, I can make sets to-order for your projects. I use OEM Beru wire, OEM Brass terminals, & even Beru's proprietary crimpers for a sound triple-crimp.
single plug wire kits: $89, twin-plug wire kits, $179. ($6 domestic shipping, $15 international)
I have Beru Red & Black available, but can also make a nice blue wire set for you as well. Yes, these are OEM-spec solid-core wire sets where you'll reuse your wire-ends to complete the ignition wire set. Hundreds sold, lots of happy people. I run my wire sets on all 4 of my turbo Porsche's. :)
Email me if I can help you out.
Mark.
1991 965 with '943.6T engine: http://forums.pelicanparts.com/uploa...1302884408.jpg
1988 944 Turbo S http://forums.pelicanparts.com/uploa...1302884458.jpg
'86 Turbo-928S
http://forums.pelicanparts.com/uploa...1302884542.jpg
'82 928 GT2R/S race car: http://forums.pelicanparts.com/uploa...1302884597.jpg
onboost 04-15-2011 11:19 AM
Mark,
your statement above; "you'll reuse your wire-ends to complete the ignition wire set."
You talking spark plug side correct?
Thx
MarkRobinson 04-15-2011 11:23 AM
All three types: distributor caps, coils, & spark plug ends: they all unscrew/re-screw back onto the new wires.http://forums.pelicanparts.com/uploa...1302891749.jpg
onboost 04-15-2011 11:52 AM
So if I'm using Tec 3 or HPV coil packs then I use my existing distributor caps?
Just trying to be clear.. all you are supplying is lengths of the actual wire? What mm ?
Thx
MarkRobinson 04-15-2011 11:54 AM
I supply the OEM style wire with the crimped ends, cut to your lengths. If your coil packs have the connectors that receive the OEM style wire ends ("M3's" as they're called, per the prior picture), then you're good.
onboost 04-15-2011 12:39 PM
Mark,
I may be up for some, I need to check the fitment of the stock end caps on the HPV coils. Never used the stock ones there before.
Thanks again for the replys..
cellison 04-17-2011 06:34 AM
dumb question, how can i determine if the wire ends i have are in good shape?
MarkRobinson 04-18-2011 09:16 AM
You can Ohm the whole wire w/o disassembling it: 1k for the distributor cap connector (check the embossed resistance rating), 0 resistance for a good wire, 3k resistance for the spark plug end: 4k total give/take 10% or so. :)
The 1k & the 3k are pretty much standard, but you should look at the embossed resistance on the plug end.
AlfonsoR 03-04-2013 06:54 PM
Mark, are you still around? If you are, has pricing changed? I have beru wires and will check their resistance. If they don't check out, I will be contacting you.
MarkRobinson 03-04-2013 06:59 PM
Yes, I'm around. You should see 4k ohms on all 7 wires, plus/minus 10% or so. Cracking or unusually rigid wires are a bad sign but also semi-unlikely. :)
Mark
AlfonsoR 03-04-2013 07:12 PM
Dang, that was quick!!! Thanks.
porsche moose 03-26-2013 07:59 PM
hi do you have a plug wire kits for a 1985 911 3.2 how much , do you have them in stock thanks Ed
porsche moose 03-26-2013 08:10 PM
hi do you have a set for 1985 911 3.2 in stock and do you know the Lent or do i have to message, thanks Ed
MarkRobinson 03-27-2013 07:32 AM
Hi Ed,
our host carries my Carrera 3.2 wires: both '84 and the '85-89 lengths, both in Beru black and red. :)
Mark
