930 Distributor rotor position
After changing the seal, I am not 100% sure that I got the distributor back in the same position as before.
I am looking for any mark, but the only mark I find on the distributor is facing towards cyl #1. I am quite sure it is placed almost like before. I have set the crank to TDC for Cyl #1 and below is what the position looks llike. ![]() Can anyone tell if this is the correct position, or where I can find the mark for the position? The car is a 78' 930 |
Isn't the #1 cyl at the hash mark at about 11:30 on the edge if the dizzy?
CCW is the rotation. Leading edge of the rotor is in the correct position for #1.
Bruce |
Why is the notch on the dizzy not lining up with the rotor?
Looks like it's about 90 degrees off.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Kind of feel that I am a little much to the left?? Is there any mark to line up towards? Quote:
Im am not sure if it is 100% lined up
Remember the crank has to turn over two full times to fire every cylinder.
Thus, you have a 50/50 chance you are at the right place to time the dist when set at TDC. You have to be at TDC and have the crank phased to be at the end or top of its compression cycle. You could pull all spark plugs except #1 and turn motor until you hit a compression stroke or just take #1 out and turn until you sense it is skipping a compression cycle and turn all the way to TDC. On some cars the rotor will not be perfectly lined up. If so I would set it to the advanced side (hits hash mark before TDC or just after the mark). |
#1 wire is suposed to be to the left of the clip and #5 to the right of the high clip.
Bruce |
Is that a 76/77? then it turns clockwise but #1 is still to the left of the clip.
The illustrating picture is taken from waynes book. Does not know which direction this distributer is for.
First picture is from my 78 930, and I think this turns counter-clockwise |
Yes it does and it is correct for #1
Bruce |
Thanks Bruce
sudo apt-get purge 930
Bringing this back for a new question. I thought I knew how the CDI/dizzy worked but not so sure now. Exactly what triggers the CDI to fire at the correct moment? The CDI discharges through the green wire to the coil inside the dizzy. Then through induction the charge is passed to the rotor and then to the spark plug wire. But what tells the CDI to discharge in the first place? Is it being triggered off RPM?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
beancounter
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Smart quod bastardus
Not quite right.
The green wire is a coaxial cable that sends a trigger signal back to the CDI box. The CDI box sends high voltage to the coil which steps it up again and sends this higher voltage to the distributor thru the center cap wire. The cap has 6 posts (1 for each plug wire) that have a copper or aluminum contact internally that gets connected as the rotor turns inside since it acts like a rotating switch. As the rotor makes contact with each post that spark plug wire fires. The signal for the green wire is generated by a little spider like assembly that has six legs inside the distributor (under the rotor) that generates a pulse signal for the CDI box to fire as it rotates. When you set your timing you turn the distrbutor housing relative to the rotor which is fixed to the shaft and fixed in relation to the crank. You are basically making the rotor come into contact with the copper contact inside the cap either earlier or later in relation to the crank position. I tried to simplify my explanation as much as possible to make it understandable.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
So looking at the first picture the rotor should line up with the "spider" tooth, correct?
Turbofrog
I can see that you can't turn the distributor 90 degrees as then the vacuum pot would be facing where the turbo oil lines are. So does it not matter which distributor (or distributor position) one uses if you can get the timing set? |
