Turbofrog
smurfbus's Avatar
Which rotor do you use with MSD?
I've burn two rotors now in a row. The last one lasted 25miles and melted. Now I installed one with 1kohm resistance.
I tried the original 930 rotor but IMO it was a too tight fit and when I got it down it did not idle under 2000rpms so I took it out and it broke while getting it out.
I haven't been able to find a resistor less rotor sofar but hopefully the 1kohm rotor lasts.
I also tried to dremel the one that was good for 5000miles but could not get any logical spots to solder any wires.
Old 05-18-2011, 10:27 AM
I've soldered a piece of thick copper ground wire from conduit romax cable across the top of stock bosch rotors and that worked and now i have one napa sells that is solid brass cross the top. It's only $4 but i don't know where i have the part number these days...
If i find that i'll post it or search napa.
Old 05-18-2011, 10:58 AM
Turbofrog
smurfbus's Avatar
Thanks, i could try to solder a wire on top of the rotor if the last one also melts. I just could not clean the epoxy and find any easy to solder spots on the one I tried?
NAPAOnlineŽ ships only to addresses in the 48 contiguous United States.
I'm in Europe so napa does not work for me.
Old 05-18-2011, 11:16 AM
Napa
I also use the NAPA rotor, Do a search here, thats where I found the part #. Here in Canada, they ding us for $12. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 05-18-2011, 12:34 PM
The napa part number for that rotor is EP407
second post: Ignition Rotor Meltdown
I called my local napa and they ordered it. picked it up the next day... $4.
Old 05-18-2011, 01:02 PM
Stranger on the Internet
patkeefe's Avatar
Subscribed. I am digesting the link JFairman inserted above. Very interesting.
Patrick E. Keefe
78 SC
Old 05-18-2011, 04:10 PM
Turbofrog
smurfbus's Avatar
Thanks J. Good stuff for archives.
Anyone: Any other resistorless rotors other than that NAPA EP407? Can't find any online shop with those that delivers to Europe. Crossing finges the 1kohm one will work and I can buy more of those for $4 and try to mod it.
Old 05-18-2011, 08:28 PM
