kodioneill's Avatar
WUR Pressure warm : question
I'm working on a 1988 turbo engine for a customer. I sent the WUR out for rebuild. When warm the control pressure is 4.1 BAR. Is this spec correct for a 88 930? Starts and runs well but I have not road tested it . This spec seems high to me. If so, what could be the problem? Foot note: the total pressure is 65 PSI.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-09-2011, 01:20 PM
3.75 +/- 0.20 bar for the 930/68.
Old 05-09-2011, 01:39 PM
Crotchety Old Bastard
RarlyL8's Avatar
As indicated that pressure is high. At 65psi the system pressure is low. Optimal system pressure is >90psi. The combination of high warm pressure and low system pressure will allow the engine to run OK but is not optimal for boost.
Old 05-09-2011, 01:51 PM
Registered Driver
Helmsy's Avatar
You say you sent it out for a rebuild. Did you tell them the specs you wanted or did they tell you what pressures they calibrated it for and is it adjustable?
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 05-09-2011, 04:25 PM
kodioneill's Avatar
They set it to the manufactures spec. So, I was wondering what could cause a high warm pressure?
1982 chiffon 911sc
Old 05-09-2011, 04:54 PM
89turbocabmike's Avatar
Well the most obvious culprit would be the WUR itself, or potentially some restriction/blockage in the return line between the WUR and the tank. At 4.1 bar your only .15 bar over spec, that's 2 psi.(how accurate is the gauge your using?) I'd be more concerned about system pressure that's 29 psi lower than the control pressure spec of 94-104 psi (6.7-7.4 bar) Ultimately the real test comes from datalogging a/f, I have an innovate lm1 with exhaust clamp for road testing,but just hopping on our chassis dyno is even easier.
Old 05-11-2011, 09:55 PM
Alan L's Avatar
You have an adjusting screw in the WUR - Allen head. You have to open the WUR. Unscrew it about 1/8 turn and it will drop your CP. It may also drop your cold Pressure a fraction, which may not be an issue.
But first, you have to get your system pressure up to around 95 psi.
No point adjusting the WUR while the system pressure is crap. When you get a proper system pressure you may find the Warm pressure is much higher again - given it is almost your system pressure.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-11-2011, 10:48 PM
Ken911's Avatar
you need to check the fuel pressure regulator and the fuel pump delivery first. If the system pressure is low then there might be a pump problem, or the pressure regulator in the fuel head needs the seals replaced. the manula has stpes for checkking fuel delivery and if thats ok then you might need to replace the spring and or seals in the pressure regulator. Out sponser sells a rebuild kit thats pretty cheap and it's easy to do.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-11-2011, 10:57 PM
