Boost guage
I have recently installed this NHS boost guage, and brake booster vac hose. It accuratly measures exactly 1/2 of what the factory guage reads. When not in boost, the guage reads -0.5, and when at full boost reads 0.5. I have a 1 bar spring, and have no reason to belive the factory guage is incorrect. Whats up? thanks Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
I have the same set up. The check valve in the brake booster is a little tricky to get back in. Maybe this is allowing pressure to escape?
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS 1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE. 2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK" |
Tinkering Pays!!
the picture shows it reading "0" - - when does it do that?
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
it shows...
0 in the pic, when the car is turned off.
Tinkering Pays!!
when you rev engine to 2-3k [while sitting still] does the boost gauge go to "0"? or, stay at -0.5?
Also, you could test the unit with a mitey-vac/pressure...
The guage moves with RPM, and when in boost, only half the reading as the factory guage, all the way up the scale to full boost. Of course the factory guage does not register vacuum, what should the vacuum reading be at idle?
I just bought the same gauge but mine goes to 2 bar and starts at 0,it doesnt have a scale for vacuum.When I'm on full boost my gauge reads .9 bar.Seems way more accurate than the factory tach one.I connected it the same way as well.Bit of a ***** getting in there for the connections though.
I have a feeling btw that your gauge could have accidentally had the guts for my gauge but the face of yours that also reads vacuum.
I'd give them a call. |
I would check the gauge or just recalibrate it - first.
mitey-vac
I don't have anything that will measure such a low reading. How would you go about re-calibrating it? Any home made contraptions I not thinking of ? Philip
I was thinking more Palo Alto - cheap money.
Mine came from NHS too. Must admit the stock gauge in the tachometer shows me using boost far more than this vacuum powered version.
C.H. Boost Addiction - honestly, I have it under control 1989 911 Turbo Cabriolet Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace |
