Toofah King Bad
Rasta Monsta's Avatar
Early Wastegate Refresh
I recently pulled the wastegate from Shaggy to pull that pesky .8 bar spring, and took the opportunity to freshen it up a bit.
PARTS NEEDED:
Studs - (4) M8x25, (4) M8x32
Copper locknuts - (8) M8
Gaskets - (2) 930 123 194 01
J-pipe gasket OR seal - 931 111 191 10 OR 931 111 195 00
Crush washers - (2) 900 123 043 30
Diaphragm - 930 123 210 01
Valve guide - fabricated
Asbestos gasket - fabricated
Copper anti-seize
Copper gasket spray
*Note - wastegate dump pipe connection to the cat has an expensive metallic sealing ring and clamp that should be inspected. They did not need replacement on this project.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-19-2011, 09:47 AM
Toofah King Bad
Apply anti-seize to studs, and start them by hand. Run them in with a stud tool until they JUST bottom. DO NOT TIGHTEN.
Here's the guide that a guy on Pelican had made for his 930. I don't have the measurements (and frankly am unqualifed to take properly precise measurements) but once your old one is pressed out a good head shop shoudl be able to replicate it. It was clearanced to .003, and felt much better than the old one, which had a ton of lateral play in the valve.
Here's the factory gasket that goes between the iron valve body and alloy housing. I think I bought the last one in existance from Andial. You MUST have a plan to fab this, as the old one will be destroyed on disassembly, and the seal here operates against intake vaccuum and boost.
Old 05-19-2011, 09:49 AM
Toofah King Bad
Hit your gasket on both sides with a little copper gasket maker to ensure a good seal.
A little more antiseize preps the top and bottom halves of the wastegate for assembly.
Note the orientation of the boost signal port relative to the dump pipe flange.
Next we assemble the wastegate "fez," upper housing, and valve.
Old 05-19-2011, 09:52 AM
Toofah King Bad
Ready for the final phase.
Factory US spring, compared to the .8 BAR 930 unit:
Don't forget to shim the spring, top and bottom.
Here's where that gym membership pays off. People complain about this part being difficult, but it ain't. Be sure to get the bracket attachment point oriented correctly.
Old 05-19-2011, 09:53 AM
Toofah King Bad
Here's the seat, which I found a bit nerve wracking. It is NOT a press fit into the valve body, it actually moves around quite a bit, and is held on only by tightening the dump pipe. Pressure from the wastegate spring aligns it with the dump valve on reassembly.
Add some studs, again with anti-seize:
Install the bracket, but only finger tight. Final alignment and tightening will take place on the car.
Old 05-19-2011, 09:54 AM
Toofah King Bad
DONE! Boost in confidence that you won't pop your motor due to wastegate fail!
Old 05-19-2011, 09:55 AM
mark houghton's Avatar
Rasta, you bad! Excellent writeup.
The last time I had my WG apart...considering rebuilding...I did all the requisite research as you have done, even found the reference to the dude that had a machine shop make his guide. And that asbestos gasket...it was leaking beforehand, along with the guide, so I just put it all back together and ran it for awhile longer before buying a Tial.
So, what material did you use in place of the asbestos (or do you have a verboten bootleg source)? And likewise, what material did the machine shop use for the guide?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 05-19-2011, 12:17 PM
Toofah King Bad
I bought the guide from a guy here who had a couple made. Perhaps he'll chime in on the material. The gasket is actually an OEM part bought from Andial, but I think it was their last.
Old 05-19-2011, 12:38 PM
Rasta,
Concur that this is a GREAT writeup. Just called ANDIAL and they must have ordered ONE MORE since you purchased yours as I just bought it! Tackling the wastegate on my 930 this weekend. Thanks again for the info. Do you know if the diaphram is the same between your 931 and the 79 930?
Toby
Toby Pennycuff
Dallas, TX
1979 930 Petrol Blue Monster
1968/1973 911S MFI #73 - Tweety Bird. 911 PCA Club Racer. E Prepared
2001 GT3 Cup #77 - O M G!
Old 06-02-2011, 03:57 PM
EmptyGarage's Avatar
Hi,
great write-up. I have one question...where do you have your jack stands contacting the car. I'm always looking for a better place?
1986 930 EFI, twin plug, lovin the sport seats
Old 06-02-2011, 06:29 PM
Toofah King Bad
Toby, wastegate is the same part.
EG, on my car there is a marking on the longitudinal box section that shows where to put the stand. . .don't know about your 911, though.
Old 06-03-2011, 05:48 AM
Great write up!
How does the car/boost feel after the refresh?
Old 06-05-2011, 06:32 AM
Tinkering Pays!!
mooney265's Avatar
Who's taking all these pictures??
BTW: best write-up I've seen to date! Makes me want to take my WG back apart and get some copper spray gasket
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 06-05-2011, 09:03 AM
