1986 930's Avatar
Removing Adhesive Script
The original owner put a "RUF" script on the deck lid of my '86 930 replacing the original "turbo" script. Since it is not a real RUF, I wanted to remove the script and put the original turbo back on. It appears to be attached with adhesive backing and there do not appear to be any posts. What can I use to loosen the adhesive without damaging the paint?
Thanks,
Mark
Mark
1986 930 Ultra-Smith/RUF Slant Nose conversion, 3.4 BTR Spec, K-27HFS, RUF IC, TIAL .9 BAR Waste Gate, 930 4 speed transmission, RUF Front Oil Cooler, RarlyL8 Headers, RUF 4 Pipe Exhaust
Old 05-27-2011, 05:14 PM
use dental floss to "separate" the emblem front the tail; hopefully the adhese will come off with the emblem leaving very little still there, then clean, use 3M solvet... clean , polish,...
Be sure there is no pin through like the OEM turbo emblem.
Old 05-27-2011, 05:38 PM
wcc wcc is offline
wcc's Avatar
Ha! I was going to say fishing line gently used bank and forth, 3m adhesive remover and wax. So we we're on the same page. Good luck!
Bill
997.2
Old 05-27-2011, 05:59 PM
steven c's Avatar
Heat it with a blow dryer first and it will go much easier. May not even need the fishing / floss.
91 964 turbo
81 ROW 911SC
11 997.2
Old 05-28-2011, 04:07 AM
What's up Bill? Hope all is well..., what about another drive together?
Old 05-28-2011, 09:04 AM
1986 930's Avatar
I am looking forward to getting home and giving this a try.
Thanks for the help!
Mark
Mark
Old 05-28-2011, 01:22 PM
wcc wcc is offline
wcc's Avatar
PM Sent..
Bill
997.2
Old 05-28-2011, 01:34 PM
acetone
I have had luck using acetone on just about anything sticky, but never on car paint. I would suggest trying an area with a small amount of acetone where it could be tested.
Old 06-04-2011, 06:02 PM
Hot sun for a few hours..floss to remove script..WD40 to remove adhesive..wax. Should take no more than 30 min.
1986 3.2 Carrera
Old 06-05-2011, 09:18 AM
1986 930's Avatar
I used the floss and removed the sticky adhesive with the Nu Finnish polish. It looks great. Now I am waiting for the Turbo Script to show up in the mail and I will mount it when I get back from playing navy. (reserves)
Thanks for all of the great advice!!
Mark
Old 06-05-2011, 09:26 AM
