-   -   Removing Adhesive Script (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/610938-removing-adhesive-script.html)
1986 930 05-27-2011 05:14 PM
The original owner put a "RUF" script on the deck lid of my '86 930 replacing the original "turbo" script. Since it is not a real RUF, I wanted to remove the script and put the original turbo back on. It appears to be attached with adhesive backing and there do not appear to be any posts. What can I use to loosen the adhesive without damaging the paint?
http://forums.pelicanparts.com/uploa...1306541604.jpg
Thanks,
Mark
Miguel Antonett 05-27-2011 05:38 PM
use dental floss to "separate" the emblem front the tail; hopefully the adhese will come off with the emblem leaving very little still there, then clean, use 3M solvet... clean , polish,...
Be sure there is no pin through like the OEM turbo emblem.
wcc 05-27-2011 05:59 PM
Ha! I was going to say fishing line gently used bank and forth, 3m adhesive remover and wax. So we we're on the same page. Good luck!
steven c 05-28-2011 04:07 AM
Heat it with a blow dryer first and it will go much easier. May not even need the fishing / floss.
Miguel Antonett 05-28-2011 09:04 AM
What's up Bill? Hope all is well..., what about another drive together?
1986 930 05-28-2011 01:22 PM
I am looking forward to getting home and giving this a try.
Thanks for the help!
Mark
wcc 05-28-2011 01:34 PM
PM Sent..
930cabman 06-04-2011 06:02 PM
acetone
I have had luck using acetone on just about anything sticky, but never on car paint. I would suggest trying an area with a small amount of acetone where it could be tested.
ben parrish 06-05-2011 09:18 AM
Hot sun for a few hours..floss to remove script..WD40 to remove adhesive..wax. Should take no more than 30 min.
1986 930 06-05-2011 09:26 AM
I used the floss and removed the sticky adhesive with the Nu Finnish polish. It looks great. Now I am waiting for the Turbo Script to show up in the mail and I will mount it when I get back from playing navy. (reserves)
Thanks for all of the great advice!!:)
