Trunk firewall cover shield thingy
Hi guys,
When you open the front trunk, in front of the firewall there is a sort of thin "shield" which sits behind the brake fluid reservoir, hides all the cables, it goes right across the front of the car, and is held on by 2 small brackets.. Well mine is in tatters, I side has holes in it for some reason, and I would like to replace it with a new one. Does anyone know the part # or where I can get a replacement. Its not a part which you can easily put and name to and search for ! thanks |
sudo apt-get purge 930
Rennline makes a much nicer version: Rennline Blower Motor Assembly Cover - Porsche-Rennline, Inc.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Perfect. Thank you.
...or from our host:
Pelican Parts - Product Information: APBZ-BC7789
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Whoa, big price difference.
the one from pelican is a good copy of the original.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I ordered the Rennline cover through our host...
Mine is kinda beat up and full of crappy holes from different stereo amps being attached to it over the years.
Can't see a fancy aluminum one under the trunk carpet so I plan to skin it with 2 layers of 8oz fiberglass cloth, and spray it satin black. |
