boost pressure sensor thread pitch
I need to move the location of the boost pressure sensor on my intercooler as it interferes with my intake manifold. The local hardware store was useless in helping. The best I can figure, the thread appears to be the same as the drain plug, m18 x 1.5mm, can anyone confirm this? I need to plug the old hole and drill and tap another location.
Thanks |
turns out it is the same as an O2 sensor, M18 x 1mm
I ended up not needing the sending unit anyway. My VEMS ECU has an output to drive the boost gauge.
| All times are GMT -8. The time now is 07:43 AM. |
