Champagne on Beer Budget
EFI distributor vs crank/cam sensors
I am working on my EFI again and stumbled across some older threads discussing the Accel 77911 distributor (dual sync)....anyone try this yet...pro's/con's?
ACCEL 77911 - ACCEL DFI Dual Sync Distributors - Overview - SummitRacing.com
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
We talk about you 87 turbo right? Then the Accel is useless, your dizzy turns counterclockwise...
I think all 3.3 turbos doSo I dont think the gear will fit. Direction itself does not matter BTW
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 08-12-2011 at 04:05 PM.. Reason: more text |
you could do what I'm doing and use a 964 3.6 flywheel conversion with the full sized 60-2 wheel configuration and use a sensor like the stock 964 Bosch sensor and sensor mount. Your 930 gear box bell housing will likely have to be notched for the sensor, but the 2 mounting holes should already be in your case...they were in my '87
![]() Patrick Motorsports - PMP 24036DMEFW 3.6L 36L CONVERSION FLYWHEEL 9 BOLT 930 G50 240MM 964 993 DME MOTRONIC PORSCHE
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Slantnose from HELL
The distributor will work fine IF.... You are running an aftermarket ECU such as a Accel DFI or any programmable fuel/spark engine management system. You will need to use your gear off your stock distributor. The rotation is irrelevant with these units. They are extremely reliable. If you want it modified for twin plug let me know. G
It changes from time to time..... Last edited by GJF; 08-14-2011 at 09:22 PM.. |
Turns out my sensors were working fine..they were just in the wrong zipcode. I had a high syncRef value (93%) which required moving of the cam sensor to bring it down to ~65%...should eliminate some of my issues.
