-   -   SC Turbo Conversion, The Result (Dyno!) (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/629769-sc-turbo-conversion-result-dyno.html)
patkeefe 11-18-2011 05:09 PM
I run the SC distributor in mine. I added a used MSD boost timing master when I did the last rebuild, along with an MSD 6AL, but the boost timing master was bad, so I am back to plain old SC distributor. I run 5 BTDC at idle, which puts me at around 27 BTDC at higher revs. I do know that if you try and retard the stock SC distributor, the car runs like crap down low. I don't think that is your boost issue. Is that a stock KKK turbo? I don't know much about the KKK's. I was going to try a stock 3LDZ, but RarlyL8 talked me out of it. The B-W T04B I have now is great, spools quickly and pulls through 6500. I also have some cheap OBX headers, which I think helps a bit.
Maybe one of the 930 guys will comment on the 7200 and it's boost characteristics.
patkeefe 11-18-2011 05:18 PM
J, some info here:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/487837-going-backwards-3ldz.html
RarlyL8 11-18-2011 08:47 PM
On a stock 930 the K27-7200 will boost about 1000rpm sooner than the 3LDZ. Yes that is huge.
voitureltd 11-18-2011 09:22 PM
Originally Posted by jcc911 (Post 6378203)
Tony, do any of those guys around here able to do a smoke test, I wonder if the late spool is due to a leak?
C.S Motorsports has one
