-   -   SC Turbo Conversion, The Result (Dyno!) (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/629769-sc-turbo-conversion-result-dyno.html)
jcc911 09-14-2011 01:20 PM
So many have asked about the result and I had an extra hour to get the car on the dyno and see where it currently stands.
Discuss...
http://forums.pelicanparts.com/uploa...1316031343.jpg
http://forums.pelicanparts.com/uploa...1316031398.jpg
http://forums.pelicanparts.com/uploa...1316031573.jpg
http://forums.pelicanparts.com/uploa...1316031604.jpg
cole930 09-14-2011 01:41 PM
Way to go bud !!!!!!
Great job well done. Car is really really nice.
Cole
jcc911 09-14-2011 01:58 PM
Thanks Cole, I appreciate the compliments. Hopefully I can enjoy it for a little while before I need to tear into again and chase the higher HP numbers.
proffighter 09-14-2011 02:21 PM
AFR's look a little too fat as boost passes 3psi until full boost is reached for a while. leaning out there would gain some HP and quicker spooling for sure.
There are different meanings how mutch, only dyno will tell exactly, but near 11.0 is too fat for sure
Nice built anyway
jcc911 09-14-2011 02:28 PM
Thanks Roland, Couldnt have done it with out your help too.
OSI930 09-14-2011 02:46 PM
Nice work! You put a ton of time and effort in on this and I and sure you learned a lot. Take some time to enjoy your success and then start the fine tuning. The car looks great.
drmatera 09-14-2011 03:16 PM
nice - just out of curiousity what gear did you dyno in? and is it a 5 speed?
jcc911 09-14-2011 03:19 PM
Yes, 915. I am pretty sure the pulls were in 4th, but was not paying that close attention as I was watching the CPU screen.
drmatera 09-14-2011 03:25 PM
On your next trip to the dyno, as mentioned above, you could add some timing and pull some fuel is the 3500- 5200rpm range if that's possible. Quicker spool up and more torque is hidden in there, but watch your a/f over 5200rpm as it seems to be going alittle lean.
First, just enjoy it..
cliyde 09-14-2011 04:31 PM
Nice job!
JohnJL 09-14-2011 06:55 PM
Well done
patkeefe 09-14-2011 07:41 PM
Jeremy:
What I got first time out on the dyno is here...http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/365597-bae-install-dyno-data.html
I think I am up around 300 now, with the Borg Warner turbo, better spool. You have some room to tweak yours. Good luck!
Rick Chip 09-15-2011 04:03 AM
Nice Job
RarlyL8 09-15-2011 04:24 AM
Looks like you've added about 50% more power; ought to be a lot of fun!
jcc911 09-15-2011 06:25 AM
Its acutally a bit more than that, but anyway, yes, plenty more fun.
wjfk32 09-15-2011 07:09 AM
Sweet looking ride..Congrats!! :)
jcc911 09-15-2011 04:33 PM
Question. Do you guys know what the in@rr means on the charts? Inertia?
patkeefe 09-15-2011 05:07 PM
I think rr is the ramp rate for that dyno, or how fast they load it. I am not sure about that specific terminology.
jcc911 09-23-2011 08:31 AM
I just confirmed pulls were done in 4th gear.
Static timing was set to 24° BTD and there was no retard when bost came on. (Thought their might be but there wasnt with the SC distributor).
911TT33 11-17-2011 04:09 AM
Is that 254HP at the wheels, or crank?
jcc911 11-17-2011 04:57 AM
Wheels my friend. :D
voitureltd 11-17-2011 06:51 AM
Also I have heard that C.S Motorsports dyno is very conservative.
jcc911 11-17-2011 08:19 AM
Conservative as I may acutally have more :) or less :( HP?
Either way am happy, just need to get it to spool quicker.
voitureltd 11-17-2011 09:43 AM
You may have more HP. I have dyno sheets from other dyno's on the same motors and Chris/ Austin's numbers seem very conservative.
911TT33 11-17-2011 01:20 PM
Cool... So that's approx 340hp at the crank. Pretty cool for a low boost bolt on job. You could expect a bit more if you go EFI With pressure sensing :cool: I'd say another 15-20hp at a guess.
I'd recommend a GT30R if you want to maximize response. A great turbo, and a perfect match for the 3.0 ;)
wjfk32 11-17-2011 01:26 PM
I would guestimate approx. around 285hp. 12%
NICE. :)
Tippy 11-17-2011 01:27 PM
34% driveline loss? :confused: :) I was thinking around 300 crank.
And yes, the GT30R sounds like a good match for the 3.0 from what I've read.
911TT33 11-17-2011 04:59 PM
Oops sorry! My math sucked! Yes, based on a 15% loss across the transaxle, that should net you ~300HP at the crank :cool:
Still, not bad for only 0.4bar of boost! I still think he can run 0.7bar safely when tuned properly.
Yep, a GT30R BB turbo with a 0.82 A/R hotside should be a very nice and fun turbo for a 8.5:1 Turbo SC! Couple that with speed density EFI and a free flowing exhaust :eek:
jcc911 11-17-2011 05:02 PM
I am running 0.5 bar. I subbed to your msd thread, interested to see how that goes.
911TT33 11-17-2011 05:13 PM
OK, so at 0.7bar (3 psi more), I would guesstimate you'd gain another (~40HP +/- 5HP) :cool:
Yeah, I'd be interested to know how well the MSD 6ABTM works on a SC turbo conversion with the BITZ EFI kit.
Might actually be more cost effective to run a basic standalone aftermarket ECU, like an Autronic SMC/Haltech/AEM/Wolf EMS with full fuel and ignition control instead of the BITZ kit + MSD 6ABTM :rolleyes:
jcc911 11-17-2011 05:32 PM
Seems like an easy 40 hp, I may even have the springs already, but am hesitant to go any higher right now. I guess I have 5+ mo. to think about it.
911TT33 11-17-2011 05:53 PM
Yep, either way, it's got to be a blast to drive compared to stock NA trim :D
jcc911 11-18-2011 03:46 AM
Like I said, the only Issue I have with it, is that I have to wind the car out to finally ge positive press and guys have said I should start at 2200.
jcc911 11-18-2011 03:55 AM
And if you search for, I think, the conversion begins, it shows the route I took.
jcc911 11-18-2011 03:56 AM
Tony, do any of those guys around here able to do a smoke test, I wonder if the late spool is due to a leak?
patkeefe 11-18-2011 02:47 PM
Jeremy,
what turbo and exhaust system are you running? And, you do have a 930 intake, don't you?
jcc911 11-18-2011 03:53 PM
Yup 930 cis. Exhaust is 993 hes with flipped flanges and m&k y pipe.
patkeefe 11-18-2011 04:22 PM
Ok. You are obviously not making pressure in the lower RPM range. It doesn't appear that you have an overly rich fueling issue from the chart. Pressure is a function of how fast and what size the compressor is, and same with the turbine. I don't recall what you have for a turbo. You may be not making spool faster because of the turbine being too large.
You could have leaks between the compressor and the throttle butterfly, or down past there into the cylinders. Could be cam overlap..what cams are you running, SC? Did you do a leakdown on the cylinders?
There exist a lot of variables to this issue.
jcc911 11-18-2011 04:51 PM
Did not do a leak down. SC cams. Cam timing done by Ben not sure what that is. Turbo is a 7200.
jcc911 11-18-2011 04:55 PM
Would running my SC distributor have anything to do with it?
