b930's Avatar
Tightening cam nut without the proper tool
My build is being held up by not being able to source a damn P237 cam holding tool. Was toying with idea of using the chains / flywheel lock to react the torque. Now I know you'll all instantly say don't do it....but surely that timing chain can take it....no?
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 11-18-2011, 09:26 PM
Probably not a good idea to tighten using the chain.
Stromski Racing has a special tool just for tightening the cam nut. It is however a bit pricey.
Rather than ordering the cam nut crowfoot and cam holder, I had a machine shop cut of the bottom 5/8'' of a 1 13/16'' 3/4" drive socket and welded a 2'' 1/2'' drive extension on the side.
To hold the cam, I cut off the box end of a 17mm combination wrench and welded about an 18'' pipe onto the open end stub. Now you can tighten the cam nut while holding the cam. It ain't "purddy" but it works.
Old 11-19-2011, 04:21 AM
