935TURBO's Avatar
BOSCH CIS fuel head upgrade....?
Hi turbomen,
who made and wich upgrades for a substencial improvement of the stock CIS fuel head....waiting my futur EFI conversion.....( next 2 years..)
Here's the head.....
The engine base is my 930/66 3.5, SC cams regrind , Pauter rods, 962 twin plug heads, HPV-1 Electromotive ignition....
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 06-14-2011, 10:08 AM
Crotchety Old Bastard
RarlyL8's Avatar
I have a few sitting on the shelf that are modified and adjusted for 400WHP.
Old 06-14-2011, 01:22 PM
Hi Serge
Why do you want to modify the fuel head ?
Just make an upgrade for fuel pumps .... you'll get much enough fuel !
965 C2T / 1991 3.3 TURBO
Old 06-15-2011, 03:22 AM
935TURBO's Avatar
Hi Thierry,
wich one did you get / are you using...?
Old 06-15-2011, 05:45 AM
Originally Posted by 935TURBO View Post
Hi Thierry,
I am currently using the 044 BOSCH MOTORSPORT (ref 0 580 254 044) in front of the car. ( And stock rear pump ) . The static fuel system pressure is set arround 7.5 bar. ( just need to shim the fuel pressure regulator). In the mean time, If possible , I also suggest you to use an adjustable WUR and/or to decrease the pressure control by 0.5 at (warm) wot. ( let's say arround 2.5 bar @wot)
With this setup, you will get enough fuel to reach safe 460 - 480 HP.
Within my pending up grade that you saw on the french board and depending the 1st results, I think I will also upgrade the rear pump by the same 044 or by B 261 205 413 . It should be ok for 520 HP without changing the injectors. Thus , if needed, I still have the possibility to install the 3.6 C2T injectors to win 5% more.
In all of case, an injectors matching flow test will help you to get balanced AFR between in cyl.
PS: excellent l'amende sous la tête d'injection
Old 06-15-2011, 06:36 AM
935TURBO's Avatar
Back to my project, and thanks Thierry for infos, did anyone use those BOSCH injectors as an upgrade vs stock injectors....? http://www.*********.com/mmparts/fuel_injectors/mercedes/560sl.html or http://www.***************/mercedes-auto-parts/mercedes-560sl-fuel_injector-replacement.html
Other question (Thierry ?)......what's the best source for the 044 fuel pump....?
Thanks.
Old 09-21-2011, 12:03 AM
Back to my project, and thanks Thierry for infos, did anyone use those BOSCH injectors as an upgrade vs stock injectors....? Mercedes 560SL Fuel Injectors - Injector - Bosch GB Remanufacturing Standard Motor Products - 1986 1989 1988 86 89 88 - *********.com or http://www.***************/mercedes-auto-parts/mercedes-560sl-fuel_injector-replacement.html
Thanks.
Hi Serge
As to the 044 itself , I bought it to R.P. in france. ( I think with the Bosch ref, many shops can provide the pump to you ).
As to the fittings, I bought these parts to SUMMIT RACING in US.
Old 09-21-2011, 06:19 AM
